Box Elder HF, Red White & Blue ??
Andy DiPietro
Andy DiPietro
>What do you think? The piece is not finished yet. It has one coat of Waterlox and the bottom will get trimmed when it dries in three weeks. I got the wood from Dominic Greco this week and I was pleasantly surprised when I cut it open. The blue is like the color of Levis original blue jeans. The piece is 6 1/2" dia x 7" tall and 1/8" wall. Comments are always welcome.
Re: Box Elder HF, Red White & Blue ??
Andy DiPietro
Re: Box Elder HF, Red White & Blue ?? PIC2
Andy DiPietro
Andy DiPietro
Re: Box Elder HF, Red White & Blue ?? PIC3
Andy DiPietro
Re: Oww-some!!!
Allen Neighbors
Carole Valentine
>Andy, I think it is going to be spectacular - both form (it already is) and figure! The blue looks dark gray on my screen. What type of finish are you planning on using?
Jim Shaver Oakville, Ont.
>Looks awesome Andy.....!!
take care,
Jim
Andy DiPietro
Andy DiPietro
>Thanks. I will apply 3 or 4 more coats of High gloss Waterlox and polish it with the beall buffs. My sweet wife told me that this is another one I can not sell. Her collection is growing.
A Beauty! Want to sell it?
TDaniel
That's right Purty and great shape also
I can't Believe you actually ..........
Ruth Niles
>asked if you should burn this piece.
It's perfect.
Dominic Greco
>Looks great Andy! I really like the overall shape and orientation of the grain. I'm glad to see you making such great use out of this wood.
Later,
Dominic
George Van
>What a beauty Andy, color, and form. I would find it difficult for someone to find fault.
Okay, I have a question
>Since nobody else asked: Am I wrong to reverse the piece while wet to turn the bottom off? I have never waited for a spigot or faceplate mount to dry. For one thing, the bowl won't be round by the time it is, so it won't fit in my vacuum chuck, and for another, I thought that the wet wood hanging on the bottom of the dry bowl might somehow impede shrinkage and make the bowl split near the bottom.
What's the scoop? How do the rest of you folks do this?
Wondering in Springtown
Re: Okay, I have a question
Dinyar Chavda
>I leave it on for sanding purposes and then take it off. I must confess that I use my vacuum system primarily as a jam chuck to take off the spigot.
I know that Russ (who is travelling and has limited access to the Internet) leaves it on all the way through to finishing.
Jorge Castaneda
>Ellis,
If the wood was reasonably dry, I'll let it stay in the faceplate and finish it later; if soaking wet, cut it righ off.
Looks terrific Andy.
Craig Daymon
>You've really got the hang of those hollow forms. Looks like you managed to get 2 chunks out of that piece Dominic gave you? Nice looking stuff. Almost like a combination of Box Elder and Buckeye Burl in coloring.
Again, great job.
-Craig
I salute you!
Joanne Adler in Pt. Pleasant, PA
>How cool looking is that! And so patriotic! I love the form, too. I have a box elder bowl that Jim Becker turned for me, but there's no blue in it. This is sharp looking.
Wally Dickerman in Arizona
>I seldom finish turn wet wood pieces. I rough turn, allow it to dry, then finish it. I leave the piece on the spigot or glue block until all of the finish has been applied. All that's left to do is part the piece off and finish the bottom.
Ellis, I agree that leaving the spigot on this piece while the wood dries, leaves a possibliity that it may crack.
Wally
Ellis, both Wally and Andy
Ruth Niles
>Ellis, they both left a very small foot and I think that's the secret. If I can't leave that small of a foot, I don't leave any because I think the thickness of the base will distort the rest of the piece more easily as you noted. I don't turn a lot of this shape so I could be wrong (my mother always says I'm wrong).
Andy DiPietro
Re: Looks terrific Andy.
Andy DiPietro
>Thanks Craig, the second chunk has a rotted branch cavity. So I am only able to get two small pieces 4" dia x 6" long. Unfortunately I broke one last night when I was scraping the inside of the collar. I will try the last piece later this week. I did save all the small cutoffs for pens etc.
Andy DiPietro
Re: Ellis, both Wally and Andy
Andy DiPietro
>Ruth, you are correct so tell your Mom. The key is a small foot. The foot on my piece has a 1" dia shaft and a 2.5" dia disc. Sometimes the disc can crack a little but the shaft does not. I like to leave a foot on so I can remount it on a 4-Jaw chuck later for sanding between finishing coats. I rotate the piece on the lathe by hand.
Both techniques work fine.
Jennifer@Indy.USA
>Ellis,
I don't do too many hollowforms...but the ones I've turned from wet wood...I either turn start to finish in one session...or I'll leave the tennon on and throw it in the denatured alcohol over night, then cover with newspaper and finish it a few weeks later. On those, I'll reverse it just to true up the tennon before putting it back in the chuck.
Jen
Allen Neighbors
>Ellis, when I turn green wood to finish thickness, and get it sanded, I immediately reverse it and finish the bottom. You're right, some woods will be more prone to crack as they dry if there is a greater thickness in the bottom... and the tenon is that greater thickness in this case. I've never turned this particular type of wood, so I can't be dogmatic about it.
Allen
Ah hah! So you ARE collecting! LOL
Carole Valentine
