Stihl Oiler
Stihl Oiler
Stihl Oiler
Nick Tuzzolino
>I have a Stihl MS 290, Farm Boss.The oiler puts out about half of what it should. I know there is a quantity contol adjuster on the bottom and I turned it all the way to full open. What's the next step to troubleshoot?
TIA Nick 90 deg in So Cal
Re: Stihl Oiler
try this:
TDaniel
>remove the bar and clean the oil hole in the bar. Also, are you using the Stihl bar oil or some other?
Re: Stihl Oiler
Re: try this:
Nick Tuzzolino
>I'll try that. Thanks. I use Home Depot oil, not sure what brand. Sounds like it might make a difference.
Re: Stihl Oiler
Re: Stihl Oiler
Robin Corell
>the oilers on these saws are gear driven such that each revolution pumps a small drop of oil. if the gears are good there is no way the oil hole can become clogged and prevent the discharge of oil. I recently replaced the oiler on my old 051, it consists two parts and a seal to the tune of about $90. Vintage parts are usually more expensive than for current model saws, but still chaper than a new saw. The new oiler throws so much oil that I had to turn it down to the lowest setting in order to keep my ankles dry, and that is running a 42" bar with .404 chain. It looks like it is clogged when I take the chain off but as soon as I start it up it clears the hole and pumps up a storm.
The oiler is easy to replace. It is accessed from a cover plate near the chain tensioning screw and also involves removing the clutch. My local shop was willing to break lose and retorque the clutch nut for a six pack. especially during saw tune up season when it takes 2 weeks to get them to answer the phone. I guess the sixer made the overtime more productive.
I prefer Sthil bar oil because it is thicker and has more 'stick' to it. I find this helps it stay on a long bar, especially for milling. I don't think it makes any diference as to the quantity the oiler will pump. Since my oiler was mostly shot when I got the saw I have no idea the chice of oil affects the life of the oil pump.
Robin
