Photo questions
Photo questions
Photo questions
Scott Hurley in N. VA
>I've just set up a photo booth using PVC pipe and a white bedsheet for the sides/top. However, I can't seem to get rid of the pink cast I get with the lights. I'm using 2 100-watt incandescent lights in reflectors, and the camera white balance set for indcandesccnt. Even with the florescent lights turned off in the room, I still get a distinct pink color in my pictures. I'm using a Nikon digital camera. In the attached picture, the top one is done in the photo booth with a white background, and the bottom one is done outside on my back porch in the morning shadow of the house with a grey background. Trying the grey background in the photo booth makes it even worse.
Do I need to get more reflective material for the sides/top of the booth (such as foam board)? Different bulbs? I tried the "reveal" lights and it was much worse. I've tried several different settings on the camera, as well as several different locations for the lights, but it always seems to come out the same.
Does anybody have any suggestions?
Thanks.
Scott
Re: Photo questions
Re: Photo questions
Carole Valentine
>I have the same problem. I have halogen bulbs. I always have to adjust the color cast, no matter what I do. Looking forward to some answers in this thread.
Re: Photo questions
Re: Every camera has a color bias, and....
Jamie Donaldson
>... the best solution is to create a custom color balance if the camera has that capability.
Re: Photo questions
New Article Coming
Garrett in Victoria BC
>Watch the 'New Articles' section a couple of weeks from now.
At out request, Jamie Cameron has prepared "The Phrugal Photo Studio Way to Shoot Woodturnings".
Cheers, Garrett
Editor, Articles & Reviews
Re: Photo questions
Re: Jamie who???Let's check the credits please!
Jamie Donaldson
Re: Photo questions
Re: Photo questions
>Scott Incandescant lamps are usually well below the tungsten white balance. Most of the digitals that I've played with have a 3200 degree kelvin white balance for the tungsten setting. Most light bulbs are 2200 to 2400 degrees kelvin. This would be red or pink when shot on the tungsten setting.
Quartz work lights and other non photo quartz lamps that I've tested run about 2700 degrees kelvin. This is still slightly warm as we photographers say which translates to slightly pink or orange.
You can buy 3200 degree quartz replacement bulbs that should match exactly but it's far cheaper to just tweak the color in your photo program if you can.
You said the photo on the bottom was shot in the shade. Did you use the "shaded building" or Cloudy day setting on the white balance. If not the photo would appear blue which is what it looks like. Daylight settings on digital cameras are probably around 5000 or 5500 degrees kelvin. ( I don't know this for sure, would have to look it up). A cloudy day without direct sun is 6000 to 6500 degrees kelvin. This means it's blue when compared to the daylight setting. That's why they put the shaded building and cloudy day settings.
Bored you yet. It gets a lot deeper but i'm going to cut it off. I'll leave with Jamies suggestion. Some cameras have a custom white balance where you shoot a white piece of paper and the camera balances it'self to the lighting. This is the best way to get close. Some cameras like our new Nikon D200 have white balance settings so that you can set the degrees Kelvin but they only set with 200 degrees of each other which is close enough to tweak.
one final tip. Color of the background will also affect the color of the piece. That's why Jamie doesn't like blue. It reflects on the piece and make the wood look cool. Wood should look warm. If you stick to black, white, or gray your auto color balance will work better.
Re: Photo questions
He was being Frugal with the credits :)
Re: Photo questions
Carole Valentine
>Obviously mine doesn't have that capability. :( Is halogen the same as tungsten?
Re: Photo questions
Re: Not in reality, but.....
Jamie Donaldson
>... Q/H lamps are usually a little more consistant in color rendering than the vast variety of tungsten bulbs.
Re: Photo questions
Re: Photo questions
>Thanks for all the quick replies. Here's another comparison. I put some 90-watt halogen floods in the booth, and the color still is quite pink (top photo in this entry). As mentioned in the first post, the background is white. This time, however, I massaged the photo with Paint Shop Pro and produced the bottom picture. Much better. I guess I'll just have to get more proficient with my photo editing program...
Jamie - my camera has several built-in 'light balance' settings, and a 'saturation control', but apparently no ability to do any custom tweaking.
John - On the original bottom picture, the white balance was set for 'outdoors'. It was a sunny morning (about 0900) when the back yard is in almost total shade.
Again, thanks for the quick responses.
Scott
Re: Photo questions
Re: Scott-the bottom image that .....
Jamie Donaldson
>.....you tweaked with software is close to accurate color, but the image is slightly underexposed. I set my camera exposure compensation at +1 due to the high reflectance of the white background, and you might improve the color somewhat with a similar correction if your camera allows.
Re: Photo questions
>Jamie has a good point and so does Carole. All the digital cameras produce a slightly different color palette. Just like using 2 different brands of film. We run into this problem at work and we use only Nikon's. Each one has a slight color bias. My Boss's canon's also vary from model to model.
Exposure also varies the color slightly. Shoot 2 different exposures of the same thing and then using only the contrast and brightness and see if you can get them to match. You will get close but often the color shifts slightly in one area or another.
One last thing we didn't mention. You don't have anything in the room that is pink, orange or red. You can often pick up colors from walls or doors that have a color.
Re: Photo questions
Just a wild guess
Juergen
>Many digital camera sensors are sensitive in the infrared spectrum. If your wife uses a detergent with a whitening agent or powdered bleach there may be residue in the sheet to which the sensor is sensitive. If you want to find out if your camera's sensor is IR sensitive find an IR remote control (check batteries) point it at your camera and press a button and simultaneously take a picture of the front of the remote. If your camera is IR sensitive there are some really fun possibilities here.
I have several roller shades in white and off white that I use as backgrounds The cheap ones cost about $5 or less at HF or Lowes. What is also nice about these shades is that one side is glossy and the other has a satin texture, which is helps to keep down the hot spots. Good luck
Re: Photo questions
Re: Just a wild guess
>Not totally wild. manufacturers but Whiteners in some detergents. These make the whites look whiter. What they will do sometimes it cause the white material to appear blue to the camera. This may be inhanced by IR or UV light and could change color since we don't see IR or UV and some films and camera sensors do.
Fuji has a new camera out that sees IR light. You put an IR filter over the camera lens and it will see only IR. They are selling it to the Forensic market.
