200+ woodworking book reviews
Vacuum and boil drying method?
Thad
>Hi all,
I came across this today, and am curious if anyone here has ever done this.
"You could try using a plastic bag and pull a hard vacuum in it. Then submerge in warm water or cover it with heating blankets. In a vacuum water will boil at 90 degrees. This would pull the water out and not put in many stresses."
Any thoughts or previous attemps at this?
~ Thad
Re: Vacuum and boil drying method?
Tony Reynolds somewhere near Newark, Ohio
>In theory it may work but I doubt you can pull a perfect or near perfect vacuum without an expense lab quality pump. And if you did have one it would out gas for many hours if not days.
Tony
Vacuum Kiln
Peter Teubel
>This is done on a production basis for some lumber. Keeping maple as light as possible is usually done this way. Cuts drying time from weeks to a few days. Google for vaccuum kiln.
Ron in Drums PA
>You would be better off in a large metal container with space on the bottom for the water to settle. Remember the water has to go somewhere.
A plastic bag would keep the water in the wood.
Barbara Gill, Remlik VA
>If I understand this corectly, the theroy is that the water in the wood would "boil" out at 90 degrees while in the bag. So you would have non vacuum boiling water with a plastic vacuum bag with the wood in it being heated? If nothing else wouldn't the bag blow up when the water in the wood turned to vapor? I may be missing something here; in fact I probably am.
Brian Hahn in SW Wisconsin
>The theory is that reducing the pressure reduces the boiling point of water. Take the pressure low enough and water will boil at just above its freezing point. (Once it is frozen, it sublimes rather than boils.) The only reason that water will boil at a lower temperature is because of the reduced pressure. As far as the bag blowing up -- the water won't boil any faster than the pump can suck out the vapor. If the pump can't keep up, the pressure will rise and the water will stop boiling.
Bill Hale / woodspinner
>Brian A few years back I posed a similar question and got a lot of can not do xcxxx ands I decided to drop the notion.
After your post I think I will try it anyway.
My idea is to build a vessel that I can put the wood in on a shelf.
Drain hole in the bottom for the drain water to go. Heat the vessel and the wood inside to 200 deg. and pull the vacuum. Hold vacuum for a couple of hours or until cool.
Just my thoughts
Bill in Casa Grande, AZ.
Bob Fawcett
>Maybe you could use a pressure cooker as a vessel.
Hmmm...
>A couple of thoughts:
I wouldn't expect any water to drain out of the wood, so the drain probably isn't necessary. There will be some foaming as air in the wood expands with the reduced pressure and forces some water out. But the water will probably boil away before it drips down into a drain. And a effective vacuum drain might be a little challenging to design.
The chambers that people use to de-gas epoxy might be a good starting point for a vacuum chamber. It doesn't need to be nearly as strong as a pressure chamber (i.e. a propane tank or water pressure tank). The maximum pressure on the chamber will only be 15 psi. And the pressure is inward, not outward, so the materials and joints only need to be strong in compression, not tension.
Re: Heat doesn't transfer well through a vacuum.
Al Crandall (NE of Indy)
>Someone on the main board a year or two ago tried to build a vacuum kiln for small pieces of exotic wood. He experienced a lot of difficulty getting the wood to heat up because the reduced molecules of air wouldn't transfer the external heat into the wood. He ran through several iterations trying to accomplish this. An archive search might keep you from repeating his errors.
Good point
>A couple of options though,
Heat the piece, place in vacuum and dry until cool, then take out and heat piece again, etc.
Direct thermal contact: heated shelf or grid that the shelf sits on.
Radiant heating - infra-red heaters, micro-wave, even a regular lightbulb.
