Has anybody used polymer clay for pen blanks?
Scott Hurley in N. VA
>My wife works with polymer clay, and she has tried to make some pen blanks for me. They seem to turn nicely, but I'm having a lot of problems with chipout between the layers of clay. Is there a trick that I'm not aware of? I'm using my Jet Mini at high speed and a very light touch with a spindle roughing gouge. Should I be doing something differently? Speed? A different gouge?
Also, what should I use to finish them? Would CA glue be a good finish? How about just wax?
Thanks.
Scott
Re: Has anybody used polymer clay for pen blanks?
Keith I in E. Tenn
>Hi Scott,
I have tried this with a couple of pens and it seemed to work ok.
I just formed the clay around the tube and baked it on instead of drilling it. I tried finishing with a normal finish (Hut) but it turned sticky after a day or two. One of the polymer clay sites I visited said this could happen and there is a special sealer just for clay. I haven't tried it yet so it will be interesting to see if anyone else chimes in.
Best of luck,
Keith
Jennifer@Indy.USA
>Scott, I think there was an article on just this in Woodturning Design a year or so ago? You may want to check into their back issues?
Jennifer
Re: Has anybody used polymer clay for pen blanks? *LINK*
Rick Allen
>Hi Scott
There have been countless pens made of Polymer Clay. The usual method is to the insides of a Bic pen.
I have turned bowls and kaleidoscopes from PC. We used to have a guy in the CAW who was a PC artist. He took his Jet mini to a PC symposium and was turning "stuff" out of PC. My recollection of his depiction was that the attendees were more interested in the colorful shavings than they were in the turned objects.
For pens on the lathe using PC as the blank material. Think about the rotation of the lathe and how the different layers overlap. If you turn with the overlap there will be less chipout. If you turn against the layers there is likely to be a LOT more chipout. This is similar to turning wood in that if you turn wood against the grain you get more tearout than when you turn wood with the grain.
Good Luck
One of MANY sites on making PC pens
Anthony Kennick
>I have turned polymer clay pens before and found the best finish to be thin CA. I use the plastic bag the pen kits come in and put a drop or two of thin CA on it, turning the blank by hand as I run the CA along the length of the tube. I let it dry (no accelerator). I put three or four thin coats on, being careful not to get any bumps. If all goes well, I use EEE to buff it up and you are done. It makes a very durable finish. I also make a lot of keyrings from the polymer clay as well. I don't have a camera handy but found a picture or one just to give you an idea.
I have found the swirled clay doesn't turn very well as mentioned in another post. I use a sharp scraper and skew for all my turning with polymer clay. It is a good medium to use as my wife is creative with the designs and I then turn 'em and make the finished product.
Where are you in N. VA? I am in Fredericksburg. My wife makes a lot of beads with the polymer clay. The best deal for buying it seems to be Michaels as they tend to put it on sale every three or four weeks.
Tony in Fredericksburg, VA
