How long?
How long?
How long?
Tony Zaffuto
>Ok, here's the story: I cut a maple tree this past June. The wood was cut to 2' pieces by 8" to 10" diameters. I am a novice at turning, having turned a rather sorry looking bowl (at least to me--wife thought it looked nice) out of redwood a few weeks ago.
So this evening, I sliced a piece of the maple about 8" long, mounted it on a face plate and proceeded to rough shape the outside of a bowl and faced it to chuck it on my dovetail jaws.
Question, how long should I wait until I hollow the bowl and otherwise finish it? The ends of the logs were not sealed when I first cut them and have been outside since cutting. Naturally being knew to this highly addictive sport, I would like to do it as soon as possible!
Thanks in advance!
T.Z.
Re: How long?
How long does it take to walk to the lathe
Bob Fawcett
>You can turn it green.
I think there is info on green turning in the articles to the left.
I am sure someone else more knowledgeable than me can tell you more about green turning.
Re: How long?
Re: How long does it take to walk to the lathe
griesbach
>Tony,
You can rough turn it right away. Leave a wall thickness of about 10% of the diameter. A little thinner at the bottom may help prevent it from cracking. Although cracking and warping are VERY common. Mark it with the date and wood species. If you wish, you can coat the end grain with a sealer such as Anchorseal. Put it in a paper bag, seal the bag and put the date and species on the bag (that way you won't have to tear the bag open to see what's inside). Depending on the temp and humidity of your location, it should be ready to finish turn in about 6 months. There are also procedures for microwave drying, and alcohol drying. You can find this info in the articles section here at WC.
I hope this helps.
Cyril
Re: How long?
>Or you can turn it to completion right now. I would do it before it starts to crack. When I turn something green I will cover it with plastic even if I stop to go the the bathroom. If there aren't any cracks now go a head and turn it down the the final size. You say this log has been sitting for a while so it's what we call seasoned. This means that much of the bound water has probably gone out but it is still considered green it's just not as wet as fresh cut.
I turn bowls like this to about 3/8" and then let them dry on a shelf without a lot of air movement. Sometimes I'll put them in a box to slow down the drying but on maple I haven't had problems. It will dry in a day or so and will warp a little. If you've turned it to an even wall thickness, bottom included it will usually just warp and not crack unless you leave the heart and pith in the log.
Theres a lot more to turning green. Do some research on the web on Green turning and you will find quite a bit.
Bill Grumbines video covers it pretty well.
Re: How long?
Re: How long? *LINK*
Darrell Feltmate
>I like to do some of the turning on the day the wood is cut. June cut maple is going to be like standing in a rain storm if turned on cutting day! Great fun. Check my site under "turning a bowl from log to salad" for my way of green wood turning. Note that this is my way and not the only way, but then this is nothing new to me. I just follow in the footsteps of people who know what they are doing. For me that is a novel thought :-)
Around the Woods
