Bits for pepper mills
WOODNUT358
>For all you pepper mill turners out there,what bits do you use to drill out your pepper mills (mainly the long bits)? I'm also looking for a source for obtaining them.I want to buy good bits,especialy the longer bits.
Re: Bits for pepper mills
Re: Bits for pepper mills *LINK*
Mike Cunningham (Cape May NJ)
>The link may help you.
I buy mine through Enco and other large distributors. The only one that really takes a beating is the 1" that is used to bore the length. Extensions can be purchased from Craft Supply and also at Lowe's. You can also turn the mill around and bore from both ends.
Mike
How to turn a peppermill
Harvey Meyer in Atlanta
>I use a 1 1/16 forstner bit with an extension. This allows me to go the distance on a 10" mill without having to come in from the other end. Go slow and clear the chips often and the bit will last a long time. I also use a 1 5/8 forstner bit for the bottom of the mill. Got both bits from Packards (I also get my peppermill kits there).
Harvey
Jay Gorday
>As it just so happens, I have been drilling out pepper mills today. I use the 1 5/8" forstner bit for the bottom, followed by a 1 1/16" bit to hold the pepper grinder and use a 1" forstner to start my hole thru the mill. I switch to a 1" spade bit and drill as far as I can go then turn the body around and drill from the other end starting with the forstner bit and finishing with the spade bit. This works fine for me.
Jay
