Cherry Haul
Cherry Haul
Cherry Haul
John Leech in 'rural' Festus, MO
>Just got finished hauling two truckloads of a recently cut cherry tree for turning. This is the first time I've done this, so obviously I have some questions to find answers to. I cut and sealed the ends of the logs with Woodcraft's green woodsealer. Cut I'm not sure if I have to remove the bark from the wood as well, or is it better/OK to leave it on?
Thanks, JP
Re: Cherry Haul
Re: Cherry Haul
Don in Central Illinis
>I usually leave the bark on. The checking/splitting you get will be on the end grain only, usually.
Re: Cherry Haul
Re: Cherry Haul
mike neitzel
>You need to rough turn asap, and seal with end-grain sealer.
You need to get the pith out of the wood asap, as it will check and split. I use a mcnaughton core saver and get as many blanks as I can from each piece. Rough turn to 1" per 10" dia. of bowl. and seal ASAP!
Put away for a year, and then bring them out,dust them off, remount on lathe, and make beautiful cherry bowls.
If you leave them in log form, they will denegrate quickly.
You need to have a marathon roughing session, FAST.
Re: Cherry Haul
Re: Cherry Haul
Tony Reynolds somewhere near Newark, Ohio
>Hi John,
Nice haul. With cherry I've had the best luck removing the pith and cutting round blanks out on the bandsaw and sealing the whole round. Even then I want to get the bowls roughed out as soon as possible. My experience of leaving cherry in log form even with the pith removed and the endgrain sealed for any length of time hasn't been good. Cherry likes to check. YMMV
Tony
Re: Cherry Haul
Get the pith out ASAP
Carole Valentine
>Then just seal the end grain and about an inch down the sides. Bark can be left on, but I have found that critters love to get under cherry bark.
Re: Cherry Haul
Re: Cherry Haul
>I agree with all who have told your to rough the bowls quickly.
I also agree with getting the pith out, even if you just cut the log section in half lengthwise it will help.
I also find that if the blank only include all heart they work better than blanks that have both sap and heartwood. Cherry tends to crack in the sapwood right down to the heartwood.
Go for it. I think cherry is my favorite wood. I tend to just put the blanks into a paper grocery bags and close them up for six months or a year. If you want, you can weigh a blank (or all of them) on an accurate scale (postage scale?) and when they stop losing weight they are ready to turn. Not a bad Idea to put the wood name and date on the blanks. In a few months you may have so many you may forget when and where and what.
Re: Cherry Haul
The other way.
Keith Newton
>I like turning green. The wood is a lot easier to work, because it is only about half as hard / dense.
Leave the bark on, seal the ends, and keep it from drying out by hosing it down every now and then when you go through a dry spell. Keep it in the shade. Yes insects love to get under the bark and into the sapwood, but I do not use that part anyway, and they don't go for the heartwood. I have left logs out there several years, and the sapwood has just turned into punk, but the heartwood is still just fine.
I like to leave the logs as large as possible.
Re: Cherry Haul
Steven Antonucci
A summary of my experience...
steve antonucci
>Cherry is a great wood to turn green, and not so bad after it has dired either. I had a 4 truckload haul a few years back and I'm finally on the last pieces.
Over time, I've discovered that checking is problematic, but bugs seem to be even worse. When the bark decays and the sapwood starts getting punky, it looks like a horror movie.
I would recommend that you take the following approach-
1.) Split out the pith in all of the bigger pieces, because they will check as fast as you can. Cut the pieces bigger then you need them, and seal the ends.
2.) On a future date, bandsaw your rounds. Remove the bark, since it'll kill your blade. seal them again.
3.) On a future date, rough out to form. Seal again, or alcohol dry. Works great with cherry.
4.) finish turn.
Bark on will lead to spalting in the sapwood over time... if your going to turn it off, then don't worry about it. I've probably turned 100 bowls in cherry in the last 2 years or so... and this is my "plan".
Steve
Re: Cherry Haul
Leo Van Der Loo
It all depends on where you live, but yes get them
Leo Van Der Loo
>roughed out as soon as possible, and no that can't all be done in a afternoon, so endseal the logs, leave on the bark, get the logs out of the sun and drying wind, and now rough ASAP, as someone said the sapwood likes to split/check, true if left to dry just in the open,(as my experience) however if taking care to slow down the drying by either bagging or/and sealing, that's not a problem. and then the sap/heartwood color difference can be looking real sharp, but that's your call of course.
I don't have good pic's from rough cherry log wood, but have some of Walnut, now just imagine taking the pith and sapwood away from those logs, I would think that's very wasteful, just MO.
Have fun and take care
Leo Van Der Loo
