Let's try again
Dave Smith, Longview, WA
>Friction polish mix equal parts:
2# cut pale shellac(shellac flakes dissolved in alcohol)*
linseed oil (tung oil for light colored material)
denatured alcohol
I recommend mixing 1 fluid ounce of each ingredient for a batch. Three ounces of friction polish goes a long way and is a lot less to clean up when you shake the bottle with the lid unscrewed.
* - From the Hock Finishes web page
"Two-pound-cut" describes two pounds of Shellac in one gallon (32 ounces in 128 fluid ounces, or 1 ounce of flakes in 4 ounces of alcohol) of alcohol. So to achieve a two-pound cut in a half-pint of alcohol, you'd mix 2 ounces of flakes, by weight, with 8 fluid ounces of alcohol.
Dave Smith
I think I understood what I meant in Longview, WA.
