We value your privacy.
>Do you mean a Sorby Steb center? For spindle work, I typically set my four prong center with a wooden mallet. I haven't really had to do that with my Steb center. I just use the center punch on both ends and mount the spindle. I use gentle pressure from the tailstock until the teeth of the Steb center just engage and sink a little into the wood. As far as your bearings getting warm, that's a question for the Nova owners. I'd figure on some heating though.
>Because they do take a bit more pressure, you are going to get a little bit more heat. I noticed the same thing. I notice the same thing with the safe drive cup center, too.
>I've had my Nova DVR XP for close to a year now. I don't remember where I read it (online or from Teknatool) but this is what I remember about the bearings. The bearings can use a little run in period and will be warmer before they are "run in". The recommendation was to run the lathe with no load at 1500 RPM or more for an hour or three. During this time you can expect the headstock casting to get quite warm near the where the spindle protrudes. You may even have some oil leak out a bit. During normal use, particularly at higher speeds the headstock casting will get quite warm to the touch - but it should not be too hot to touch! If it is you have a bearing problem. I would expect that it would also be noisy if it was creating this much heat.
I did the run in procedure on my lathe and it did indeed get rather warm, I also notice that the casting will heat up when I run it at higher speeds for a long time. In particular, when I make a number of small tops, I'm not really asking the bearings to do much but run fast for awhile - I.E. not much of a load.
If you have any concerns about your lathe contact Teknatool support in the US - The guys name is Tim Giest I think. The contact info should be in the manuals, I can look it up and send it if you can't find it. Their support is great, in my opinion (a satisfied customer).
>Ron, as I said, I don't remember exactly where I read it. It may have been on the CD they included buried in with other FAQ's or it may have been from a Teknatool person on the MSN Nova owners group. At the time, the Teknatool site had the stuf on the CD on it also so I may have read it there.
