Seeking feedback on Kutzall carving disk?
Keith Newton
>I am working on a project that is mostly sculptural, and am using the lancelot wheel, with the chain-saw teeth, followed by coarse 24 grit sanding disk which works fine for quick cutting and fairing, but the sanding disk works best if it is used with a slight tilt with a swiping motion where the cutting is from the middle of the disk out, but it tends to burn if you push the edge up against a steep edge.
I am wondering if anyone is using these kutzall wheels, and if they cut well, and or if they have a tendency to load up and burn. This project is cherry. If they load up, how do you clean them. Do they do a nice job of fairing from gentle curves into steeper curves?
I would just like to hear any feedback pro, or con. Thanks
Re: Seeking feedback on Kutzall carving disk?
Gary in Zirconia, NC
>They can be cleaned with a wire brush. If plugged solid, they can be burned with a propane torch, it won't hurt the wheel. I like the wheels.
>Keith I do most of my carving with the chainsaw cutter and then go to flex shaft carvers with teeth that look like the cutzall. They are easy to clean with a wire brush or torch. They will burn cherry if you don't cut cleanly. I'm probaby running them at a slower speed than you would with the big Kutzall discs on an angle grinder. I still think light cuts would be necessary.
Pascal Oudet
>Keith,
I've been using the arbortech very often lately. I purchased the Kutzall wheel in Louisville, and use it from time to time, but the big concern I have with it is that it generates a lot of fine dust (much finer than the arbortech), throwing it everywhere. (btw, it's the same with the other kutzall bits). apart from this, I haven't seen it clogging (some dust accumulate in the center, but I just blow it off with compressed air), and it does a fine job when you need a more precise work than with the arbortech (or lancelot) cutter.
Pascal
