compressor noise help please
ken chase
>The compressor noise is driving me crazy. I thought of building a large box to place it in but don't know how much space to leave around the compressor for air. Suggestions will be greatly appreciated.
Thanks
ken chase
Thanks
Re: compressor noise help please
Norm Smith in Nova Scotia
>Ken, My compressor was driving me crazy also. I built a box making it weather tight and put it outside. I ran a hose through my basement wall. Works great.
Norm
MountainMan
>Hey Norm...
Do the neighbors like the noise?? HeH!! HeH!! - My Grizzly 1029 makes more noise thn the 5 ga. Sanborn...
Regards
The MountainMan
>Mountain Man, They havent complained yet and I hope that they dont.
Norm
eliot d
>You probably have an oil-less compressor, as I do. They are known to be very loud. I understand that the ones that use oil are less noisy.
Leo Van Der Loo
>Norm you should be able to stifle most of that noise, it's probably the air intake air's shock waves that make most of the noise.
I think if you would make a gun silencer kind of noise damper, that your noise would be greatly reduced, just rig one up out of some scrap pieces and give it a try.
Just make the baffle kind, a couple of long paint spray cans or "foam in a can" cans, open one side, make some washer type baffles from thin metal and spacers from say a large size hose or even card board tubing would work for a while stack all the baffles and spacers in the cans and tape it all together some fiberglass insulation and a second skin around the whole contraption will increase the effectiveness of the whole, you have to mount this either in front or in between the filter and intake opening on your compressor, that should make the airflow go much more smoothly and quiet things down, just give it a try, and no no guaranties.
Have fun and take care
Leo Van Der Loo
Nissan Teman
>I had the same problem with a noisy compressor and tried most anything. What worked for me was building a double walled plywood box and gluing 1 inch (25mm) thick acoustic foam (waffle pattern foam) to the inside wall of the whole box. I used a small (4") bathroom exhaust fan to pull out the hot air, with air in and out through a labyrinth type baffle. I left about 10" airspace on each side of the compressor enclosed in the box and when it is on you can hardly hear it-no more noise than a refrigerator in your kitchen.
Before I tried the acoustic foam, which is expensive, I tried several other types of insulation, with little noise reduction. I put cellulose insulation between the double walls of the box and I also tried "egg crate" type mattress foam and tried regular cardboard egg crate to line the inside of the box, to little effect.
The acoustic foam did the trick. Whatis important is to keep the inside of the box from getting hot and burning out your compressor motor. The exhaust fan seems to be sufficient. Now if I only did not have to open the box periodically to drain water out of the compressor.
Good luck
ken chase
>Thanks much for this great post. I'm sure this is the answer to my problem
