Homemade Airshield Battery Pack *LINK*
Gary Ratajczak
>Hello all
I promised someone on the "messages" side I would post some instructions for my battery pack replacement solution. Thought I would share with the Turning group also.
Hope it proves useful.
http://woodworker.homestead.com/MiscPage.html
Re: Homemade Airshield Battery Pack *LINK*
Carole Valentine
>Thanks, Gary.
Jennifer@Indy.USA
>Fantastic Gary! I have one of the new and one of the old style Trend batteries and they don't last the four hours they claim them to. I really appreciate this information!
Jennifer
Thanks, Gary. Very Timely For Me.
Clem Wixted, Jonesboro, AR
Russ Babbitt Jr.
>I have one of the older faceshields. I disassembled the battery pack then took it to the local "battery store". They replaced the batteries and all for less than $10. A deal. I was getting ready to build my own pack before I discovered them. I think it was Batteries Plus.
Gary Ratajczak
>Russ:
Main reason I built mine was not just to replace the batteries, but to get a pack that actually fit into my shield. Also, the ability to use low cost cells in a stand alone charger lets me keep a sufficient handful of fully charged spares to keep me going.
The batteries+ method is a good one if you are happy with the speed of the charger (supplied unit takes almost all night), and if your pack actually fits - mine did not.
If anyone has any comments on the fit of the original, I would be interested. Like I said - mine was VERY difficult to get in - to the point I was worried I was going to break something.
John Kyler
>I made one from a NiMh cordless phone battery pack from RS that met the capacity very close to the original. Cost was $16 total with the plug. Uses the original charger etc.
Tom Minehan
>Can you use the charger that came with the Airshield to charge this battery set up?
Gary Ratajczak
>As far as the supplied charger, it is a very slow charge. As the new cells are over twice the capacity, it would take an even longer time. I'll look at the specs on that unit. Advantage of one of the newer drop in style chargers is that most have a conditioning circuit built in to better take care of the cells.
Can't say for sure, other than I don't. The way I looked at it was a new pack from Trend was almost $40.00 anyway. I invested less than that, and got multiple packs.
ERWIN NISTLER
>Thanks for the p[ost. My batteries are down to less then 2 hours. I was about to order a new pack. Now i will have a better pack for much less $$$$$
Dennis Daudelin
>Thanks Gary, this is a life saver. My batteries have just been cutting out. I don't like the original charger as there is no way to tell when they are properly charged. And worse yet, you can't just leave them in the charger like you can do with most all battery chargers these days!!
Once again, thank you!!
Dennis
Semi-hijack, but on topic
Rod Peterson -- Ormond Beach
>I have given some thought to rigging an extension line from the helmet (the connector is a standard sized coaxial DC connector available at Shady O'Rack) to a reasonably sized gel cell with bunches more milliamp hours than the 3 AA cell arrangement. It could be strapped on the back of my belt, or even just set on a work area behind me. For that matter, I could just plug it into a 12V power supply (not a wall widget) and dispense with charging issues altogether. I have several of those laying around. I just haven't gotten around to working out how best to drop the voltage.
Anyone have any thoughts on that?
Rod
Re: Semi-hijack, but on topic
Fog Tanner
>The idea of the battery pack on the belt is the best. I have an Airstream which has a belt mounted battery pack (5500ma I believe). I bought a 2" wide leather work belt which I use for that battery, that I just put on like a gun belt over my other belt. Before that I just used my Norm tool belt turned around backwards - worked great. It is in the back and out of the way. You can get some D or C size cells and make up a large pack that will run your unit all day. My pack is good for about 9 hours, would be a lot longer on a Powervisor or Airshield. For those you would want a belt mounted unit.
I would not want an extension cord hanging off me as I will wear the airstream while I go back and forth to the bandsaw and grinder. I also wouldn't want to get tangled in a cord while working around the lathe.
What is the manufacturer thinking?
Jim
>You'd think the manufacturer would clue in....
