Have a question? Ask Woody!
"Modification" to Wolverine Jig
Dominic Greco in Richboro PA
>Hello Everyone,
Like many of you here, I have the Wolverine Jig by Oneway. However, I've always been dissapointed in the flat tool rest that they give you. The fingernail grind jig works fantastic, as does the skew chisel jig. But I've always had a bit of a problem with the flat tool rest. You know the one I'm talking about. It's a flat table that can be adjusted to just about any angle. Unless you modify it somewhat extensively, you really can't use jigs to hold you plane blades or chisels when you're grinding the bevels.
Is it me or was the Wolvering Jig designed for someone who is JUST a turner. Some of us actually do work on the "flat side" now and again.
Now I know that I should LEARN to develope a steady hand and be able to perform this operation WITHOUT a jig. But I love the ease at which a jig lets to get a repeatable, clean grind. So bearing this in mind, I made up my mind to modify my Wolverine Jig.
I removed the left hand too guide and the flat tool rest and replaced it with the Veritas Grinder Tool Rest. I actually had this tool rest installed on my hand powered grinder for a while. But I didn't find it ideally suited for this application. The Veritas Grinding Jig and Veritas Skew Grinding Jig I have require 2 hands. And one was always needed to turn the handle (yeah I know I could make the hand grinder "foot powered" easily enough. But I didn't have the room)
Over this past weekend while I was turning some items, I found that I had no problem using the Veritas Grinder Tool Rest to sharpen my various scrapers, 3 point tool, or parting tool. In fact, I thought it was actually EASIER.
Where the tool rest really shines is with the (Radiused) Skew Grinding Jig (purchased with a gift certificate my wife gave me for my Bday last week). I have a 3/4" wide Sorby Skew that I always wanted to convert to a radiused skew. With the Skew Grindng Jig, it was done in about 5 minutes and gave me an edge that looked great! I can't wait to try this out on my plane blades. I've got no less than 5 that need to be reground so that I can use the sharpening techniques Ellis and Alan tutored me in (at the last 5 Barn's BBQ).
Has anyone else felt the need to modify their Wolvering Jig this way?
See ya around,
My ugly mug
Dominic
Re: "Modification" to Wolverine Jig
Re: No, but I might....
Allen Neighbors
>if I could just see a pic of what you're talking about.... :o)
I guess the links didn't help
>'cause I thought that they would. Each link I posted contains photos of what I'm talking about. Take a look at the Wolv Jig photo in the first link. Then remove the tool "platform" (as Oneway calls it), and the associated piece that hold it. Replace it with a Veritas Grinder Rest shown in the link for it.
>Dominic. I actually have one of those. It's been kind of retired. I used to use it on my wet wheel grinder and retired it when I got the wolverine. I may pull it out again.
Re: "Modification" to Wolverine Jig *LINK*
Peter Teubel
>"Has anyone else felt the need to modify their Wolvering Jig this way? "
Nope. That's why Oneway came up with their Flat Tool Jig.
Flat Tool Jig for the Wolverine System
Yeah, I saw that but
>after I read some of the reviews about it in a couple WW Mags (FWW I believe gave it a so-so rating), looking at it during a visit to a local WW store, and seeing the $80 price tag(!), I decided I could live without it. :>)
And since I already had the Veritas Grinder Rest, it was really just a matter of joining the two.
Re: I guess the links didn't help
Allen Neighbors
>Sorry, Dom, I'm just dense!. :o)
Thanks for posting.
How did you wed the Veritas to the Wolverine?
Charles R. Smith
>Dominic, I must be really dense. I stood there for 10 minutes trying to figure how you married the Veritas unit to the Wolverine setup. For we (me, actually) who are mechanically inept, would you kindly explain it in a bit more detail? Thanks so much! Charles in Victoria.
Re: "Replacement" to Wolverine Jig
Ben Aragon
>Hi Dominic,
I have both jigs on separate grinders, I like them both a lot.
I know what you mean about the Wolverine flat tool rest jig. I�ve thought about making a new platform rest for the Wolverine that will accept the Veritex accessories.
Ben
Noow that you mention it,
Jorge Castaneda
>Yes, I did that inmediately as soon as I had the Wolverine, I had been using the Veritas jig already, but now & then I want to put back the original grinding table without the slot, as I find myself falling in the slot and sometimes damaging the edge, which brings me to what you mentioned already, now I am leaning heavily to learn to grind, "au naturel" just hand eye coordination and free myself from the jigs.
By the way, call me old fashioned, I like my skew edges straight and maintain my edges on an oil stone! No jig at all. Only when I managed to put a nick I use the grinder to remove the nick and back to the india oilstone for the sharpening, and a hard arkansas for honing.
How I did it...
Edward in Vancouver
>I've got the Veritas jig too, need it for plane irons and the like. Since I only have one white Norton wheel on my grinder, (the other is a felt buffer)I traced the outline of the Veritas base on a piece of 1/4" hardboard and cut out the center, so the base of the Veritas jig sits very snugly inside the hardboard template. Then I removed the Wolverine jig but not the base. Next I placed the Veritas base in it's hardboard template at the choice location and fixed the location of the hardboard template onto the plywood base of my grinder with finishing nails. Drilled two holes in the plywood base that my grinder is mounted on to match the holes for the Veritas base, and in these holes screwed in two 1/4" poppet nuts.
When I want to use the Veritas jig, I slide the Wolverine jig out and pop the Veritas jig into the hardboard template and fasten it down to the grinder's plywood base with two 1/4" threaded knobs which screw into the poppet nuts. The hardboard template assures me that the Veritas jig is consistently and accurately placed, and the threaded knobs allow me to remove the Veritas jig completely so I can pop back in the Wolverine jig.
Spent a couple of nights staring up at the cieling thinking up of that one....
Bingo!
Jorge Castaneda
>Edward,
You have a good engineering mind, that is a good and practicalsolution, thank you for sharing it.
So you use the felt wheel for honing, what I have been using for plane irons and such is a faceplate with a piece of medium density fiber board, once trued, all it takes is a little buffing compound a a light touch, works great.
Thanks again
jorge
Re: Bingo!
Edward in Vancouver
>Me an engineer? CN or CP? (two CDN N'tl railroads...) Nope, just a professional cook who likes to fool around with wood.
Trying to make the most out of my current lathe, a tubular bed Crafstman that I bought as a teenager way back when. When I can milk all I can out of that one, I'll fork out some serious coin for a "good" lathe... Strangley enough, this lathe, well, clones of it, are still being made and sold. Canadian Tire (a large hardware/auto store) sells it, albeit with a few modifactions, one of them being a cast tool rest base. The Craftsman has a stamped steel bed that relies on a tight connection with the steel strip that runs along the bottom of the steel tube. No matter how tight I screw it, the toolrest base still moves. I'filed off the pop rivets that hold the strip to the bed and tapped the holes to accept hex-head machine screws. The strip is tight now, but the bed still moves. Then I examined the bed more closely: The base relies on a cut out groove in the stamped steel to match perfectly with the steel strip, but there is slop between these two, resulting in movement. I filed a piece of mild steel to match the profile of the steel strip and bolted this to the tool rest base. Much less movement, but the whole thing still flexes. Finally I gave up and trotted off to Canadian Tire and ordered the cast iron tool rest base, these are available as well as (3/4"x 16 tpi) face plates and other hardware particular to the lathe. For ten bucks I figure, it's worth the gamble. I'll let you know how it works out.
Re: Great Idea...
Ben Aragon
>Great idea.
I'll take a photo
Dominic Greco
>And post it here as soon as I can.
Dominic
Garrett in Victoria BC
>Yep, did it several years ago when I made a version of the Wolverine jig.
Cheers, Garrett
Jorge Castaneda
>Hi Garret,
Good one!
That blue grinder looks good, who makes it?
jorge
looks like a Baldor
Bob Elliott
Thanks!
Jorge Castaneda
