Carole, Nova Questions
Jorge Castaneda
>Hi Carole,
If I remember correctly, when you got your lathe you got the outrigger tool rest as well.
Have you used it? If so how do you like it and how much room it takes?. I am considering getting one, but space is at premium in my little work space. If you can post a picture, that would be grand and much appreciated.
Thank you very much
Jorge
Re: Carole, Nova Questions
Carole Valentine
>Hi Jorge, I do have it but have not used it much because I always swivel the headstock for my hollow forms and bowls and I do not do large platters (yet). The tool rest distance from the work is very limited when using the outrigger. The slot in it sure makes a handy storage area for my live centers and my spur centers though and the tool rest post is handy for storing my knockout bar. :)) Guess what I am saying is if I had it to do over again, I would not buy it. I may change my mind if I start doing big platters, but big is not really my thing.
Re: Carole, Nova Questions *LINK*
Colin Spencer
>Jorge, I have one and like Carol do not use it much. I find that if I need to turn anything large (not huge) I just rotate the headstock and the standard tool rest on the ways is sufficient. If you want to turn 20"+ stuff then it is a must. It takes very little room. I'll try and do you a photo a bit later. You can possibly just make it out in the photo at the link below but I'll do a better photo later.
My lathe with outrigger
>Jorge I had one with my Nova when I had it. I didn't really like it. The tools vibrated when I used it so I had to rig up a threaded rod that went from the gap in the outrigger bed to the ground. I would tighten up a nut underneath until you couldn't move the outrigger. That's stopped the vibration but of course you had to move it every time you move the rest.
That was the second problem. To turn large bowls I would rotate the headstock. Then set up the outrigger and turn part of the bowl. then it would be too large to move the outrigger so you had to either dismantle the tool post which was a hassle, or remove the bowl, move the tool rest and put the bowl back on.
I sold the outrigger and then sold the lathe and got a bigger lathe.
Thanks Carole,
Jorge Castaneda
>I have a growing number of blanks that are just a little too big for turning over the ways and I don't want to make them smaller, as it took the tree a long time to grow and I have good luck selling big bowls and now platters.
I must confess I have not used the swivelling head much, I better start trying that.
An honest opinion is worth a lot,
Thank you again
Jorge
Gracias Colin! Nice site
Jorge Castaneda
>The picure is enough to give me an idea of the space it takes and from the answers I got now I don't think I will get it.
I enjoyed your site very much, I am a fan of your poliginal bowls.
Gracias
Jorge
Thanks John
Jorge Castaneda
>I love this forum, in a few hours, thanks to you wonderful people, I've gone from wanting it bad to better bid my time, save my farthings and go for the bigger lathe, just as you did, I have the Powermatic 20 - 35 in mind.
Thank you very much!
Jorge
Re: Thanks Carole,
Carole Valentine
>Jorge, I would recommend that you get one of those little taper gizmos that fits into the spindle so you can realign your headstock precisely with the tailstock when you bring it back in line after using the swivel feature. My detent is off by just a hair. I imagine most of them are.
Re: Thanks Carole,
Jorge Castaneda
>Yes, mine is off too by quite a bit, that's why I do not move the head.
I'll get the gizmo.
Thanks again
Jorge
>I have a DVR and do not have the outrigger. I turned one bowl that was maximum capacity of the lathe, but the blank was too big. I swiveled the head stock and mounted the blank. Then I realized I had no tool rest on the left side, so I put the set screw in the chuck, locking it on the shaft and ran the lathe in reverse. Used the regular tool rest and cut all the corners off the blank until it would clear the ways. Swiveled it back over the ways and used the regular tool rest for all of it. Managed to turn a 15 3/4" bowl on a 16" lathe.
I have a friend that turns for a living. He turns a few large bowls to take to shows. Some as much as 24". Says people look at them and ooh and ahh, but they rarely sell because most people have no place to put one and no real use for one.
Do any of you have a different experience?
Colin Spencer
>Jorge, Thanks for the comments about the site and my five sided bowls. Here's a photo as promised eeven though you have decided not to follow through with the purchase. As you can see when it is stowed it takes up very little additional room.
Jorge Castaneda
>Colin,
That is a neat arrangement and sure it does not take space; my lathe has a vibration problem that I am unable to solve so far, after reading John's post I thought it only will get worst with the outrigger.
Some day I hope to have a shop as organized and neat as yours...
Thanks
Jorge
DD
>I noticed in your pictures you have a remote start/stop buttons configured for your Nova DVR. How did you wire it up? I would love to add the same to my own DVR. I am running version 4.22 of the firmware, if that matters.
Thanks,
Doug
Carole Valentine
>Jorge, what kind of vibration problem? The headstock, the bed, the whole bemch? Is it at all speeds?
Nova DVR remote switching *LINK*
Colin Spencer
>Doug, It is easy to do f you can solder electronic components or know a friend who can. The key pad on the Nova DVR just plugs in to the circuit board with a 10 way 0.1" pitch connector. All I did was create a small circuit board that went between the Nova's connecting plug and cocket and connected a new start, stop and speed up / down switch in parallel. The pin assignments I found on the Nova group on MSN in some photos by Walt Ahlgrim. the link to these photos should work below but if not go to the third page of photos select Walt's album and they are on his page 2. I find the remote really useful and I have it with a hook and a magnet on the back and so can position it anywhere. If you need any more info just ask.
Walt's photo page
Jorge Castaneda
>Carole,
It has a couple things, when I touch a tool to the tool rest, it hums like a tunning fork, the other is a thump on the head that gets worst with bigger pieces and or higher speeds. It happens at all speeds, the one where it happens less is 360. The lathe is a Nova 3000 and the vibration causes a washboard effect specially in the inside of big bowls. I should have returned it before the one year warranty, but was too busy with work and that slid by.
Re: Nova DVR remote switching
DD
>Colin,
Thanks very much for the information. I will certainly give it a try. It seems like a very handy (and safe) device to have around a lathe.
Doug
Carole Valentine
>Yikes, Jorge! That sounds awful. I don't know anything about the 3000. Mine is a DVR. Perhaps someone in the Nova Owners Group could help? Or you could talk to Tim Geist and see if he has any suggestions.
I am sure you have checked this but
Carole Valentine
>how is your lathe mounted? The mounting bolts on the headstock (at least for the DVR), from what I understand can bottom out if they are a tad too long. That can cause all sorts of vibration. Just a thought. Would be nice if it were that easy!
Re: I am sure you have checked this but
Jorge Castaneda
>the lathe is mounted in a shop made stand made out of plywood, the top is 2 layers of 5/8" glued together and the lathe is bolted down, just snug on the bolts, did not tightened, I tried tight and found it's worse. The trouble is in the head, just a single bearing and that may be a bad bearing that may be the thump, there are also issues with the motor pulley that may be the reason of the tunning fork.
Thanks for reminding me of Tim Geist, I really need to talk to him...
