I NEED HELP ASAP!!!!
Blake Washburn
>I have many problems with my lathe that I'm very concerned about.
1). When I turn something at a high speed and I take deep cuts my lathe shuts off and the little "reset" button comes out and I have to wait for a little "click" so I can push it back in and the lathe will start working again.
2). My "on and off" switch doesn't want to work half the time. I either can't turn it on or I can't turn it off. It just wont stay in the on or off position.
3). Today I was turning and I had to press the "reset" button many times and my "on and off" switch is stuck on "on" so I turn the lathe on with a power strip. Then the "reset" button stopped coming out when the lathe shut off so I had to pull it out and press it back in. This occured a couple of times. The third time I did it and when I pressed the "reset" button back iN, MY LATHE DIDN'T TURN ON!!! I turned the power strip off and when I turned it on the lathe ran for a split second.
So I checked to see if the switches were working and everything and MY LAHE IS DEAD!!!!! I NEED HELP GUYS!!!!
Blake Washburn
13 year-old turner
Re: I NEED HELP ASAP!!!!
Tony Reynolds somewhere near Newark, Ohio
>Hi Blake,
You didn't say what lathe you're using, but it sounds like the thermal overload switch was trying to protect your motor. You may have burnt up the motor. It sounds like you're trying to take bigger cuts than your lathe will allow. Large cuts at high speed is tough on motors. Maybe if you tell us what lathe and motor size and how big the wood was someone can give you a better answer. Hoping for the best....
Tony
I have....
Blake Washburn
>a Jet mini lathe with variable speed. And when I say deep cuts I don't mean DEEEEEEEEP cuts I mean maybe 3/8" shavings and the lathe is going about 2000 RPM.
Blake Washburn
John Bussom
>You stated you turned the power strip off so I take it you are running with an extension cord, have you moved the lathe closer to the power source and tried without power strip???
They are a source of a lot of problems, your lathe may be drawing more amps than strip will allow, ie not enough electric for lathe to run.
example, at work we recently added new equipment and used some powerstrips for a temporary source to plug everything while new building and proper power outlets were being built/installed, then our packers seemed to think they could have 2 fans running too since there were 2 available outlets, results were frequent conveyor belt stoppings etc... disconnected fans and equipment ran on one machine, on the other we made a trip to wally world at 2 am to get another strip to get it running again!
Really hope it is only the strip that went bad and not your lathe!
Jamie Donaldson
>I also believe you were using too high a speed, a problem shared with many turners. Not only is it not necessary, but unsafe as well- things happen too quickly, and most of them bad. I have had my Stubby for more than 5 years, and if has never been over the low gear setting of 1200 RPM for any bowl turning. Of course most spindle turning is done at speeds higher than bowls, but remember that very high speeds are usually not necessary.
Phil Joines Krum, Tx
>I don't have the VS so don't know if dust is a problem with the motors. It might have gotten into both the motor reducing the cooling air flow and the thermal switch causing it to be eratic.
Carole Valentine
>Just curious...why were you taking such heavy cuts at such high speed on such a small lathe?
keith zimmerman, Normal IL
>Blake, I suffered through the same thing on my Jet mini VS. I kept tripping the breaker on it, even when doing light cuts. Eventually, my on/off switch failed too. I contacted Jet and ordered a new switch. After replacing it, all is well. It has been almost 2 years since that happened and there has not been another occurance.
Contact Jet and get a new on/off switch. If your problem is like mine, that should take care of it for you.
keithz
You beat me to it!
Jorge Castaneda
>I was just to say that...
>I looked at my jet power supply. You may have 2 problems. I think I'll agree with the others. That big a cut on the VS lathe will cause a lot of strain on the motor. Hopefully the reset switch saved the power supply. You may have 2 problems, bad switch and the overtaxing of the motor is kicking the reset switch too often. The reset switch may be bad also. With luck there aren't any other problems in the power supply. You might be able to find one of the those one off switches locally. It's nothing unusual. If that doesn't work order one from Jet. If the switch doesn't solve the problem try replacing the reset.
I wold also take the lathe somewhere that you can plug it directly into an outlet without an extension cord to make sure that isn't part of the problem.
The power supply isn't outrageiously expensive but the motor is. Hopefully it's not a motor problem.
Jim Terry
>Blake, The power switch and the reset are wired in series. It sounds like you may have a bad power toggle switch. If it goes bad and opens up there is no way to get power to the motor. The reset is actually an 8 amp thermal breaker. You should not have trouble getting the power switch to stay in either the on or off position. If it does not snap from one position to the other then it needs to be replaced. Good luck and hope that is all that is wrong
Jim
MY LATHE IS NOW RUNNING...
Blake Washburn
>like a champ. I got inside the box of all the components and adjusted parts on the switch and now my lathe and switch work. Thanks soooooooooooooooo much for the help and solutions to my problem. I'm so glad that this site exists where experts and fellow turners can help each other out. Again, thanks for all the help (now I won't get grounded).
Blake Washburn
13 year old turner
Re: MY LATHE IS NOW RUNNING...
>Blake,
That is exactly what this place is all about.
I'm pleased that you got your lathe working again.
keithz
Grounded?
>I spent most of my High School career grounded. I wasn't that bad a kid I just always got caught. Glad you came out of it OK.
The switch
>Talked to several club members who have the VS yesterday. It seems having problems with the main switch isn't uncommon. One solution takes a trip to a boat parts or off road vehicle supplier. There is a rubber cap available that screws over the toggle. It's used to keep water out of the switch but would work just fine for dust too. The switch is a standard shape and if I needed to replace one I'd go with a 20 amp. The heaver contacts and more positive action should make the replacement trouble free.
I'd still.......
>be very wary of making those big cuts at that high of speed. Glad it turned out something simple to fix. Stay safe and have fun.
Tony
Re: Blake, you've received some
Allen Neighbors
>good advice from this post. I'd like to add a little to one of them.
One person told you it would be better to not use an extension cord.
An extension cord adds resistance to the line for the electricity to travel over on the way to your lathe. It is hard on your motor to have to draw the power over that distance. I used a 12/3 extension cord about 6 feet long to connect my Grinder to electricity. My grinder got really hot when I was shaping a tool grind. When I moved my Grinder closer to the outlet, and did away with the extension cord, it quit getting hot. Now I can have it on as long as I need it... no problem.
Just a suggestion.
Have fun, and above all, stay safe.
Allen
