The trouble with lasers
eliot d
>More accurately -- the trouble with me. I was hollowing a flatish 'river stone' HF using the Elbo constrainting rig, and the overarm laser light to control the thickness. I was nearly done ( after many hours ) and was thinning down the under side part of the form to match the thickness of the rest of the form -- and SWISH went right through! It's an interesting sculpture now.! What happened, you ask. Well, I was intent on that little laser dot, which was shining on the BACK side of the vessel. Do you see? Has this ever happened to you? The laser dot doesn't do you much good on the "wrong" side -- at least not for me when not thinking clearly -- because the dot is, so to speak, 'south' (on the headstock side) of the cutting tip, which can go right through. and it did! Bummer! Cut it right in half--jagged -- in the blink of an eve.
Ed Karsh: I show it to you all tomorrow at the CAW meeting.
Re: The trouble with lasers
>And on really odd shaped vessels you have to constantly move the lazar in relation to the cutting tip or you get inaccurate readings(that's politically correct for cutting through the side). Not that I've ever done that you understand "my friend" has done it several times.
For those who don't know the imaginary line from the cutting tip to the lazar needs to be perpendicular to the side being measured.
Re: That's why I don't turn with....
Jamie Donaldson
>... a laser aid- they give you a false sense of security, and you spend more time constantly adjusting the gadgets than actually turning.
>I find them much faster for initial hollowing. I don't have to worry so much about where I'm cutting. Once it gets thin I either stop and measure or I'm a little more careful with the lazar. As long as you know they are not perfect they work well. As soon as you assume thier foolproof your a gonner.
