Henry Taylor Spear Point Scrapers
Jennifer@Indy.USA
>Hi Everybody....
...well I'm over at Craft Supplies shopping for goodies, and came upon the Henry Taylor Spear Point Scrapers and am seeking advice on how this tool could be used as a shear scraper for the interior of a bowl as stated in the description? I can understand the outside of the bowl...but the inside? Am I not getting it? It says it has dual radius edges... but it appears to me that both sides of the point are straight...and I just don't see it able to shear scrape the inside of a bowl?
If somebody has the switch to flip the light bulb on....please do so.
Thanks,
Jen (in the dark)
Re: Henry Taylor Spear Point Scrapers
gil jones
>My 'bulb' is burned out on that one, young lady, good luck.
Gil
Leo Van Der Loo
Funnel type bowl ??
Leo Van Der Loo
Fog Tanner
>I have one and the point is a little longer than the one in the pic. And both sides are curved not straight as the pic. I use it mainly for flat work like platters and the outside bowls, but have used it on the inside of some bowls. Pitched on its side about 45 degrees and used in a pulling motion. The curve on the point only lets a small amount of the edge in contact and I wouldn't get one without the curved sides. But, it would depends on the shape of the bowl as to how far or if you can use it. For my it normally used on the outside and around the foot these days. After going to a Clay Foster demo, I have taken to using a goose neck cabinet scraper for the inside of bowls where I need a scraper to level tool marks.
goose neck cabinet scraper?
Tom Libby
Me too? Fog , more info please.
Norm Smith in Nova Scotia
could that be a miss print?
Bob Elliott
>I have the tool and also had a 5 day class with Raffan a few years ago. He never used it on the interior of a bowl. As I recall, he used it to clean up small details, refine the tenon for the chuck and for exterior use on bowls.
Re: Me too? Fog , more info please.
>I bought a set of three cabinet scrapers from Woodcraft. A rectangle, one with a convex end, a concave end and two straight sides, and the goose neck or sort of amoeba shaped one. I have been using them on bowls, both inside and out. I use the straight one on the outside and find a curve on the others that suits the inside. No real sure, but I think I am doing the negative rake thing. I tilt the cutting edge downward and at an angle to the wood and find a sweet spot and they cut like magic. And you can also use them with the bowl standing still and work on an individual spot of tear out.
I don't have a lot of experience, but it seems to be better than tuning with turning tools and it seems to save significant sanding. I would suggest you get the tool rest back out of the way and be sure there is nothing to get tangles up in. Also be careful of the other edges, these things are sharp all the way around.
Now I need a lesson on sharpening them.
Ron in Drums PA
>I've been using a cabinet scraper for the outside of bowls.
My problem is I can't sharpen a goose neck cabinet scraper very well.
Bingo!
Carole Valentine
>I never have figured out how to sharpen that thing and keep the curves right.
It's Pretty Obvious Jen...
>The picture you are showing shows the part of the tool that you hold onto. What is not shown is the rounded wooden part of the tool. That's the part that goes on the inside of a bowl. I have used this tool and so far I find that it is uncomfortable to handle and the wooden scraper end is quite inefficient.
Hope that helps.
Tommy
Re: It's Pretty Obvious Jen...
Jennifer@Indy.USA
>Tommy leave it to YOU to figure it out!
Smart @$$
Fog Tanner
>My use came out of necessity, I was turning and eccentric bowl with two intersecting bowls or cavitys - each inself eccentric. The first was no problem in finishing. The second was a different story, the piece of wood had spilt in it which was allowing some movement and therefore a some tool marks. Much more and the piece would have blown up. I tried sanding the tool marks out and did go through some 60 grit. While I was sanding I remembered the Clay Foster demo where he used a cabinet scraper on the outside of a piece. So I gout out the set I have, which has goose neck scraper in it.
If you have ever watched David Marks woodworking show, he uses a scraper on everything. For using on a bowl, the goose neck scraper is used in much the same way, with the top tilted towards you at around somewhere between thirty and forty five degrees, you can either pull the scraper towards you with the lathe off or with the lathe on at a slow speed. I cut around the 5:00-6:00 oclock area. I went from the 60 grit, to sanding with 220 after the scraper.
Sharpening is fairly simple, you take a diamond hone or flat stone and flatten the sides removing the previous hook. Then place the scraper in a vise and take a piece of hardened tool stool (a gouge will do) and one end and hold it across the edge at ninty degrees and then tilt it at five or ten degrees to one side and pull down the scraper. Feel the hook and if it feels good you are ready. Do the same to the other side and you have two cutting surfaces. A 6" cabinet scraper will have over 2 feet of cutting area this way. You can also use the Vertias Burnisher to do this too.
Jim King
>Jennifer: I consider that the most useful tool I have. Only difference we make them out of old files.
Barry Turner
>I think your success will be limited to it's use on the outside of bowls.......or other convex surfaces.
