Online how-to for "Scoops"?
Dominic Greco in Richboro PA
>Hi everyone,
So I'm talking with my Mom tonight and she mentions these wooden scoops she saw at a local gormet cookware store. She then tells me how nice of a project these would be for me to make. Now, I'm not the most alert person in the world (as my wife will gladly attest to). But even I could see where this was leading! :>) Besides, if they're easy enough to make, I'm sure they'd be a real hit as Xmas gifts for my family.
So, I was just wondering if anyone knew of an online article (or even one that's been published in a wood mag) that outlines the procedure for turning wooden scoops like the kind Richard Raffan and Nick Cook are known for.
I've looked on Yahoo and was only able to find references to the Raffan book and some web sites that sell the scoops.
I imagine that they're somewhat straight forward to turn. You turn the shape, hollow it, and use a bandsaw to arrive at the final shape. Or would you bandsaw out the profile while it's still square?......
See why I'd like to read up on this?
Any help?
Thanks,
Dominic
Re: Online how-to for "Scoops"?
Dennis in Southern Oregon
>Dominic, I took a couple of courses under Richard Raffan a few years ago. Scoops were one of the early class projects. You start with a cylinder chucked at the handle end. Then you hollow the open end to a depth roughly equal to the diameter of the blank. Richard uses a "back-hollowing" technique with a spindle gouge for the rough hollowing, followed by a scraper to clean it up. Next measure the depth of the bowl, mark the result on the outside, and part down to almost the diameter of the desired handle on the chuck side of the mark. Then shape the outside of the bowl, checking thicknes with your fingers as you go. (Richard would use a skew for this.) Then turn the handle to your liking. If needed, you can stuff the bowl with paper towels and bring the tailstock up against the latter for support. (Note: you do not want a very long handle if the scoop is to used in a canister.) Finally, part off the scoop cleanly with the skew or gouge. The final shaping is done on a bandsaw (very carefully) or on a belt sander. Good luck, they are fun to make. Dennis
Bill Turpin in WNC mountains
>Fine Wood Working Nov/Dec 91
Popular Woodworking Jan 90
Woodturning Dec 97
Bill In WNC mountains
Jennifer@Indy.USA
>Dom,
Ruth Niles makes some really cute scoops. I think she calls them coffee scoops.
Jen
Re: Online how-to for "Scoops"?  *LINK*
Turning an alternate scoop
>Dom, I also saw Richard Raffin make a couple of these, just as described above. I have made a few and so has my son. the scary part for me was the bandsaw part. I had one get away from me and mangle itself and fly around a bit. Its a case of if you don't hang on tightly, its more likely to get away, but if you do hang on too tightly its more likely to jerk your fingers into the saw.
If you are going to make a bunch, I would suggest some sort of holder or sled for the bandsaw part. And a sharp blade.
Phil Joines Krum, Tx
>Why not use a coping or other hand saw?
Steven Antonucci
AAW tutorial on The Woodworking Channel *LINK*
steve antonucci
>It runs all of the time, and the one the guy makes is SWEET.
Steve
All kinds of stuff here
saw by HAND!?
Dominic Greco
>You mean people actually still do THAT!? :>)
I was thinking that using a coping saw would be an option. But then I would actually have to learn to use one properly. You should have seen the difficulties I had using a coping saw last year when I was finishing off the baby's room! I ended up using a jig saw with one of those special bases.
See ya around,
Dominic
Thanks everyone!
Dominic Greco
>I appreciate the suggestions and recommendations. I'll look over the web sites you all provided and take a look when I get home. Hopefully I'll be posting pics of the ones I made soon.
See ya around,
Dominic
Walter Ahlgrim
>Step by step directions with photos in the St Louis woodturner�s newsletter February 2006 page 4. free to the public at our web site.
Walt A
Woodturners of St. Louis
That's why they call it coping! ;>)
Re: AAW tutorial on The Woodworking Channel
HeatherA
>Steve, which guy?
Thanks,
Heather
Re: saw by HAND!?
>When I was a kid I was taught by a master trim carpenter to use a coping saw with the blade positioned to cut on the pull stroke. I think they used to come that way, but all the ones i see now cut on the push stroke. Make much more sense to cut by pulling. That way, the pull keeps the blade taught and you don't have to rely on the strength of the frame. When I do trim, I put the work on a bench that is about chest high and operate the saw from underneath.
Steven Antonucci
I think his name is Soren Berger?
steve antonucci
>or pretty close to that. He turns them multi-axis... flawless finish.
Steve
Re: saw by HAND!?
>I know what you mean, I see them backwards all the time. I use a pull cut on any saw with a frame, hack, fret ,etc. The frames aren't desidned to resist the stress of a push cut.
