200+ woodworking book reviews
Bandsaw Blades from Highland Hardware
Dick Gerard bowlman
>A while back there were some postings about the "Woodturners Bandsaw Blades" available from Highland Hardware. Since I needed a new blade I ordered 3, along with some parts to rebuild my old Delta 14" bandsaw (polyurethane tires, tire brush, tension spring and rapid cranks tensioning handle and rod).
The order arrived in 3 days! And fellow turners, I have to saw, those blades are the BEST EVER. Over the years I have used nearly every brand in every configuration of teeth per inch, hook, rake and skip, including carbide tipped blades.
These blades sliced through 13+" of wet sappy Ambrosia maple so easily I thought I had a much more powerful bandsaw. And the radius cutting ability has to be seen to be believed. I know some others of you have already used these blades, but for those who haven't ... go get 'em! They really do what they claim. A rare thing these days. Mark me one VERY happy and satisfied turner-customer.
Re: Bandsaw Blades from Highland Hardware
Allen Neighbors
>I like those blades, too. However, in April, I ordered two. (JL brought them to me at the Georgia Gathering. Nothing I'd ever used cut as well as they. In June, I ordered three more, because the other two broke. Now I have only one, out of those three, left. I use the 1/4" Blades.
Previously, I used 3/16" blades that I ordered from Grizzly. The Grizzly blades never cut like these, but they didn't break as readily, either.
Adjustment is as per the guide on the back of the saw. Wonder what I'm doing wrong?
Allen
Carole Valentine
>Never could get mine onto my saw. Haven't bothered to hassle with returning it.
Al, I have only broken two bandsaw blades in two years. One was my own stupid fault and the other was faulty weld, which LV replaced immediately. I can't believe you have broken that many since the Gathering! Maybe you have the tension too high? Did the blade slip onto your wheels fairly easily like your other baldes? Mine did not. The one I got is so short that even if I could get it on my saw, the normal tension scale on the saw would be way too high.
Allen Neighbors
>Carole, everything that I've read on bandsaws tells me to tighten the tension a "little bit" tighter than the guage calls for. I haven't done that but a couple of times, and it didn't seem to make a difference in how they last. In the 16 years that I've had this bandsaw, I'll wager I haven't replaced more than 5 that were dull. All the rest have broken. I know that I've caused a couple of them to break by doing something stupid, but I don't think the rest of them were my fault. I usually bought the 3/16" blades 10 at a time from Grizzly. (I used to use the 3/16" all the time, making bandsaw boxes.) Now, for sawing blanks, I buy the 1/4" blades from Highland, and they break just like the rest.
I don't know what the deal is with this Crapsman saw, but I never try to force feed the wood, and don't try to make too tight a curve, and the blades still break.
Carole Valentine
>Allen, maybe you need a little more blade for cutting blanks. What's the tpi on the blades you have been using? I use a 3/8" 3 tpi and I think they have an alternate set on the teeth but I can't remember. Sounds like it's possible that your blade might be heating up. That's just a guess, mind you! What I know about bandsaws is a little less than nothing! LOL Maybe someone else can help.
Hooligan
>Most likely the fact that you are in such a narrow blade is creating stress on the band. I don't use anything under 3/8" on mine, and try to stay at 1/2". When I am cutting logs down, a lot of the time I go to a 3/4" band.
Also, in blades that small, you are creating a lot of stress on the weld when you are cutting green wood. Think of it like this, when you have a piece of string in your hands and pull it taught, it goes straight. When you bring the ends closer together, it buckles. The same principle applies to a band in the kerf. You are sort of forcing the blade onto itself, so to speak, causing it to buckle.
Allen Neighbors
>I don't know what the tpi is on these blades. But maybe I should go to a 3/8. Maybe that'll help me use one til it's dull!! Thanks, Carole, I'll give that a try.
Allen Neighbors
>Hooligan... funny, I haven't used that word for years... After reading Carole's and your posts, I guess I'm going to give it a try... the 3/8". Maybe that'll help me out. What is the smallest circle you can cut with a 3/8" blade? Will it do a 6" blank in wet wood, without getting in a bind?
