Canes and Epoxy question.
>I have a commission to turn a number of canes. The client provided a brass handle and a kit that includes a center fitting that screws together, so the cane is in two pieces. He also provided the walnut for the canes.
This has been an interesting project. I made the two tapered pieces which are about 16" long, but they are not perfectly cylindrical tapers. They are about 3/100" "fat" in the center. I thought that only my "turner's eye" would spot it. Nope, he asked if there was some way to remove the slight bulge?
I made one, carefully following the instructions that came with the fittings. I am not happy with the way one piece fits the brass. Unfortunately, I epoxied them together. Is there a solvent for epoxy?
And where can I buy more fittings?
Re: Canes and Epoxy question.
>Heat is the best thing I know of. You might try putting a screw or nut in the brass fitting and heating that. If you heat the brass directly you could change the color. I've always just used a propane torch to heat some metal screwed into epoxied inserts. It doesn't have to be that hot to break the hold so thier may be other ways to heat the metal.
Ron in Drums PA
>I found out the hard way that DNA disolves epxoy
>As Ron suggested DNA might work. You can also try acetone or isopropyl alcohol.
Re: Canes parts at Lee Valley
>Those are the ones. My client has had them so long he had no idea where he got them. Thanks. Now if I must I can order replacements.
Bob Oswin
>Try turning the connection down with a file it's not too proud.
If you glue(attach)a strip of sanding paper to a flat piece of plywood or the like you can level the taper on the pieces by laying the stick down the length while you rotate the stick at low speed.
I am hoping you didn't try to turn it in two sections then join it?.
Bob
Re: Canes and Epoxy question. *LINK*
Russell L. Babbitt Jr.
>Try Craft Supply.
Craft Supply
Tom Minehan
>Depending on the epoxy used, the heat from a hair dryer may be enough. I use a hair dryer to remove the tip tops from graphite fishing rods without damage to the rod or the top.
Uhhh, Yes I did......
>turn it in two parts and join it. My lathe has a short bed and I could not have turned it in one piece. The part that caught my interest was drilling the holes in the ends of the pieces for the connector. It occurred to me that they had to be drilled really accurately or the canes would be crooked. Did not want the to end up with an elbow in them, so I set up a gig on the drill press. (this would be a perfect job for a horizontal boring machine.)
The instructions said to drill a hole that was the "root" diameter of the threads on the fitting and then screw the two halves together at once. Using each to twist against the other. I was sure the would split, so I paled with tapping one side, but the crappy tap I have just "drilled" out the hole. So I resorted to drilling the holes slightly larger and adding epoxy to fill in the gaps and add strength.
Drill the hole first
Phil Joines Krum, Tx
>Use a cone center in the tailstock to hold it. That way the hole is centered. If you have a hollow tail center you can drill through it but if the drill is smaller than the hole you need to make a bushing to center the drill. If the piece needs holes in both ends make a "driver" with a plug the center the headstock end of the piece. That's how I do lamp standards.
Re: Uhhh, Yes I did......
Albertabob
>"turn it in two parts and join it. My lathe has a short bed and I could not have turned it in one piece."
I am not sure I would tackle this job using the equipment you have available for a "commission".
It might be better to make one for your self first to see where the pitfalls are before getting into a jam with a customer.
If you are going to persue this style of turning I strongly suggest you extend your bed or seek a different lathe.
Not saying it can't be done but, it's crap shoot your way.
""The part that caught my interest was drilling the holes in the ends of the pieces for the connector. It occurred to me that they had to be drilled really accurately or the canes would be crooked. Did not want the to end up with an elbow in them, so I set up a gig on the drill press. (this would be a perfect job for a horizontal boring machine.) ""
The next thing that could have saved you a bit of time and aggravation would have been a Jacobs drill chuck mounted on a suitable taper and inserted in the tailstock with the appropriste drill.
To keep your part dead center, I would suggest you make or buy a steady rest and mount that before you drill the end of the stock to keep everything parallel and centered.
Hope this helps.
Regards
Bob
Leo Van Der Loo
Another way to hold your cane
Leo Van Der Loo
>Barry I have a pic. from a simple steady that someone put up, for people on the rec wood turning site, and it is really KISS, this way you are able to drill right in the center, and also if you are afraid that the cane might split when you screw in the connector, tighten a hose clamp on the shaft before turning in the connector screw.
Have fun and take care
Leo Van Der Loo
