DNA procedure question
Ed Moore
>I have a large red oak bowl that is 1 1/2" thick and has been coated in Anchorseal. Suppose I were to take the surface off, so as to get rid of the Anchorseal, and soak the bowl in DNA for a couple of days. Then, after a couple of weeks, turn the bowl down to 5/16" or 3/8".
My question: Should I then soak the bowl in DNA again?
If so, for how long?
When is the bowl ready for final sanding and finish?
Thanks,
Ed
Re: DNA procedure question
Ric Taylor
Ric Taylor
>Ed,
If it were my project, I would trim it down to about an inch thick before soaking in DNA. Then, after it has dried per Dave Smith's instructions, it should be ready for final turning and finishing.
Ric
Tony Reynolds somewhere near Newark, Ohio
>Hi Ed,
I've used Mineral spirits to remove the AS let it surface dry then soak in DNA. After allowing to dry for 2 weeks or so (I use a moisture meter and dry to 12%MC) you can finish turn, sand, and finish. No need to resoak as it's already dry. Soaking 24 hrs has worked fine on my 15" and larger rough outs that were 1.5" thick. Always good to have enough wood to true up after the warpping of drying.
Tony
Brad Vietje
Would like to hear from David Smith on this...
Brad Vietje
>Great question, Ed.
I wonder if Red Oak will dry as quickly as other woods soaked in DNA in the first place. In my experience, it takes a lot longer to air dry than hard, fine-grained wood like Sugar Maple, so I wonder if it takes longer w/DNA, too. I don't know why Red Oak seems to take so long to dry, since it seems so porous, but this gets at the difference between free water, which is lost pretty quickly, and bound water, which can take a long time.
I would imagine White Oak would also take longer than most woods, even longer than Red Oak, but since White Oak is rare around here, I've never had any green logs to play with. Anyone have some info on using DNA with oak species ?
To help with the original question, if you want a finished Red Oak bowl in minimal time, I've had pretty good luck drying Red Oak in the microwave, using multiple, gentle cycles (3 - 4 min at 50% at 750 watts), with about 20 - 30 minutes cooling between each session.
Safe spinning,
Brad Vietje
Newbury, VT
Brad, oak is a 7 on a scale of:
TDaniel
>1 to 8, 8 being the most difficult. I think walnut is about a 4 if my memory is correct. I have not used the alcohol method yet.
I did a couple of red oak
Don Henthorn
>bowls with the alcohol method and they dried just as fast as any other wood I have tried.
Philip F Duffy
>Ed, I have used the DNA for some time now but the expert is Dave. My expectation is that the red oak will move somewhat after ruff turning so I would soak it again, for 24 hrs and then let it dry as Dave suggests. Just be sure you have not left any indications of the pith or all kinds of bad things will happen! Phil
Red oak should dry just fine with alcohol soak. *LINK*
Dave Smith, Longview, WA
>Hi Ed,
I have documentation of drying a white oak bowl on my Alcohol Soaking Blog. I have dried red oak bowls in the past with no problems. An inch and a half sounds a little thick to me. How big is the bowl? In my experience turning bowls to less than the 10% of diameter rule of thumb results in less distortion and degradation. Thinner walls will develop less stress and will dry faster. Please refer to the alcohol soaking blog I have provided to explain the process and answer questions. Feel free to email me of phone me if you need more explanation.
360-636-0721
Dave Smith
Back in my shop in Longview, WA.
