Veritas - Innovation in Tools
CA Glue Question
CA Glue Question
CA Glue Question
Gary Ratajczak
>Attended a general woodworking meeting last night, and the speaker mentioned he uses water to accelerate CA glue. Did not have a chance to talk with him.
Does anyone use this method? Do you mist both pieces, or only one? His comment was that it did not cause the glue to bubble and turn white. Just cures - instant.
Thanks all....
Re: CA Glue Question
Lan Brady
>Gary,
CA glue cures when it reaches a pH of 7. It will reach that level slowly when exposed to air. The liquid only accelerates the time to cure. Water will work.
I personally use rubbing alcohol. That way I have ready sterilization for my cuts and scrapes handy.
Lan
Ric Taylor
Ric Taylor
>Gary,
Water will work, but in fact it does increase the chances of causing the CA to crystalize and turn white. I would recommend just going ahead and using the accellerant that is made by the same company that produces the CA, for the best overall results. It costs a little more, but over the course of many projects, the results are worth it.
Ric
>I've tried all the "cheapo" methods of accelorating CA glue. CA accelorator works best. Water will work.
Fog Tanner
>I have some primo pieces of balsa wood that have been sitting for 25 years which are too dry for CA. You can put two pieces together, run a bead of glue and they fall apart as if there had never been any glue at all. For those I mist on some water and they glue as normal. For the most part I try not to use any of the accelerators in structutal areas as they weaken the glue joint, but I'll use them in cosmetic applications with the thicker versions.
Over the years there have been some of the accelerators that would create a fuzzy growth. Sometimes it had to do with when you put the accelerator on (before or after) and sometimes it was the brand and formulation. And if you look around you will find a number of "home brews", which for some strange reason seem to only work for the guy expousing them.
Steven Antonucci
I've used baking soda in water...
steve antonucci
>and water
and spit in a pinch...
All work, but "the real stuff" works best. had an incident where the CA was cured on the outside, and not on the inside... got it in my eye- and yes it was as bad as it sounds...
just buy the "real stuff" to be 100% sure.
Steve
Bill Hale / Woodspinner
>I have posed this question before, What is CA accelerator and can I make it ?
Water etc. seems to work but with secondary problems. I am a cheapskate and would like to brew my own if I can.
Nothing works like the real stuff !
Bill in Casa Grande AZ.
