new jet mini tool rest
>I replace the stock tool rest with a solid steel tool rest. I also like to make the ends thinner so I can reach around it when turning small spindles.
Re: new jet mini tool rest
keith zimmerman, Normal, IL
>Looks good. It looks to be about 6" wide, is that close? How about a pic of the other side? I'm interested in seeing how you designed it.
Thanks,
keithz
>I'll photograph it tonight and show you why I design them this way.
Bob Moffett
Bob Moffett
>John,
Are you interested in selling some of these and if so, how much.
Thanks,
BobM.
>Bob It takes me too long to make them. I don't have the best tools to cut the tool rest. I did finally buy an antique powered hacksaw and that really makes it easy to cut the Drill rod.
>Here's the backside of the tool rest. Don't pay attention to the mediocre weld. I'm still learning.
top view
>Here is a top view. You need to make the tool rest stick forward enought the work will clear the banjo with the tool rest up against it. I grind off the front angle so you can get the tool rest as close as possible to the work.
