Cleaning Ways?
Cleaning Ways?
Cleaning Ways?
Charlie Anderson
>I just finished roughing the exterior of a very green cherry bowl. To my surprise, the ways had changed for a bright color to a brown.
Using paint thinner, I scrubbed them but that didn't brighten them up. I did get alot of brown on the rag is was using.
The ways had been waxed but that probably wears away sliding the banjo and tailstock around.
What's a good way to get them clean up again?
Re: Cleaning Ways?
Re: Cleaning Ways?
Carole Valentine
>I use WD40 and one of those abrasive blocks that I used to use on my table saw. Works great for me. Wipe down afterwards and use some paste wax.
Re: Cleaning Ways?
Steven Antonucci
Why bother? Doesn't affect the performance?
steve antonucci
Re: Cleaning Ways?
Re: Cleaning Ways?
Russell L. Babbitt Jr.
>I second the WD40 and an abrasive pad or sandpaper. It is part of lathe maintenance for me.
Re: Cleaning Ways?
Re: Why bother? Doesn't affect the performance?
Rick Bane
>i use top saver spray and a brown abrasive pad. works great and it stays on for a longer time than any oils or waxes that i have tried. hope it helps!!
Rick
Re: Cleaning Ways?
Me too. WD40 steel wool followed by wax
Re: Cleaning Ways?
Re: WD 40 and gray ScotchBrite pad.
JamieDonaldson
Re: Cleaning Ways?
I beg to disagree
Carole Valentine
>My banjo slides much easier when the ways are clean.
Re: Cleaning Ways?
Re: Carole-you don't have to .....
JamieDonaldson
>....beg to disagree with anyone!
Re: Cleaning Ways?
Carole Valentine
>Shocked you, huh Jamie! Usually I just flat-out say what I'm thinking and beg nothing! Must be the moon phase making me a little more mellow. ;))
Re: Cleaning Ways?
Re: I beg to disagree
>My tool rest chatters when I move it if I don't keep the ways clean. People used to say that not cleaning the ways will stop the tailstock from slipping. This is true but it also keeps it and the tool rest from moving smoothly. It's not the proper fix for this problem. The flatness of the tailstock base, the size of the clamping plate and how the lever locks the tailstock are the real problems. Robert Vaughan did a great job demonstrating how to take care of these problems at the Tennessee Symposium many years ago.
I believe the ways should be clean but of course each person has to decide for themselves. I'm probably anal about it.
Re: Cleaning Ways?
Re: Stop Begging
>Your point's valid.
But defining "clean" might be a better idea. If clean means (to you) the waxed glare off the bumper of a '55 Buick, then you may need some supervised couch time. If however, clean simply means little or no rust or finish drips and splatters, then I'll suggest you're on the right track. I clean mine with a wallpaper scraper and a little fine emory with penetrating oil that then gets wiped off. WD40 is not, after all, much of a lubricant, and will get gummy after air-drying for a short while. Of course that merely helps the fixtures stick where set while inhibiting rust. But ixnay on the axway, Ghraashoppah! It actually attracts and absorbs water vapor from the air which will pit your ferric metal ways making them progressively harder to clean.
m
Re: Cleaning Ways?
Allen Neighbors
>What you say makes common sense. :o) When the toolrest and tailstock operate smoothly, it makes for a better day... and probably a better turning, too.
Re: Cleaning Ways?
Re: Cleaning Ways?
Lynn Edwards
>I live in a very humid Florida and my lathe is in an un-conditioned shed that is almost always moist. I treated the lathe ways with phosphoric acid. It stops rust and keeps it from starting. You can find it in a paint store as a metal treatment before painting or in an aersol can at your friendly NAPA dealer.
Re: Cleaning Ways?
Re:Is rust converter actually a form....
Jamie Donaldson
>...phosphoric acid? I use the WD40 or BoeShield for the rust inhibitor qualities, and not as a lubricant. Besides, WD40 smells good!
Re: Cleaning Ways?
Re: Thanks everyone
Charlie Anderson
>After I finished roughing the bowl today, I'll test some of these methods.
Re: Cleaning Ways?
Re: Cleaning Ways?
eliot d
>Hi Charlie. Would you believe no less an authority than David Ellsworth actually advocates leaving wet shavings on the bed until it rusts! His position is that it makes the banjo rock hard on the bed with less slip and vibration, etc. I spoke to him briefly in Louisville about that, telling him that I just couldn't bring myself to do it. He just smiled and let it go. Anyway, you've gotten good advice from others; and I do just about what they say -- some WD40 and light emory or whatever. Still, David E. is the man, and he prefers function over form on this one! (One reason --for me --that I couldn't possibly take his advice, anyway, is that I have the Powermatic 2035A, with a sliding headstok!)
Re: Cleaning Ways?
Re: Cleaning Ways?
Bill Hale / Woodspinner
>I always remember the first AAW show I went to.
Went to watch the first pro and he stated that you need to sand the ways so the tailstock doesn't move !
Second Pro says be sure to keep the ways clean, polished and oiled so the banjo and tailstock move smoothly.
Ok I say clean and smooth but who cares about a little stain !
Bill in Casa grande, AZ.
