We value your privacy.
>You might get a better tumbling action if you can tilt the piece and possibly make it off center. I think if it had a wedge with the center thick it would tilt up and down as it rotated. This would cause the rock to slide up and down as well as around. If the whole thing was off center it might result in a swirling action.
>Tilting the piece down is probably better for smoothing the area near the opening. A piece of wood, with a slight tenon cut to fit the opening, and taped on the piece will keep the medium inside.
I agree with you about that sort of action (up and down, in addition to around) would be much better than just turning around, but making it do that is beyond me... right now.
I haven't turned a hollowform in a few days, now, so I haven't been able to put this tumbler to a test. I previously used an electric Ice Cream maker motor. It was taped together. :o) But I never tried to tilt it.
I want to smooth the entire inside. A 1/2" opening is too small for most people to get a finger into, so they can't feel it... I just want it to be smooth! (I want to be able to tell Wally that it's "sanded" to (whatever the grit of the medium is... most cases about 5 grit :o)
