We value your privacy.
>How do you turn those vases and bowls that are 1 to 2" in size ??!! I have no idea how you set up the stock, attach it to the lathe and what tool[s] to use. I would like to try to turn a small item but have no idea where to start. Should I just tape a piece of sandpaper to a toothpick and go for it?
Books, websites, videos, etc are appreciated. Marianne
>It depends a lot on what you want to make. I have a 1/4" gouge that I can make some pretty small stuff with. I also have smaller gouges and small skews. The small skews I make my self. Look in the catalogs at the Bonnie Klein mini tool set. It is excellent. I make a small gouge out of round stock that doesn't have a flute. It works really well for small stuff. Later tonight I'll try to post a photo of one. It's very easy to make from small screwdrivers and such.
To attach the wood to the lathe I use all sorts of techniques but most of the times it's just a chuck with small jaws or I glue the the wood to a larger scrap piece and put that in the chuck. Quite often when I turn something like a Christmas ornament there will be a small end piece left. I'll turn a small bowl or hollow vessel out of this.
I turn them just like I would any other piece: start with the stock between centers, turn a tenon for the chuck, reverse it and then start shaping and hollowing. If your stock is not long enough, use a glue block. Sometimes I even use a woodworm but that usually makes a hole a bit bigger than I want for an opening so I will put a little collar on the piece. I could make a screw chuck with a smaller diameter screw, but just have not gotten around to it yet.I use mostly homemade tools ground from allen wrenches or drill stock and then put a decent size handle on them. The most worthless tools I have ever purchased were a set of Sorby mini hollowers which I got on sale. They *may* be ok once I regrind them and put a handle bigger than a Magic Marker on them! :)
>For shaping the outside, I use my regular 3/8" bowl gouge and a spindle gouge. Once I have hollowed, I don't generally reverse chuck the small guys. I just part them off with a concave base.
>I also cut the bottom off without reverse turning. Of course mine are so small you can't reverse turn them. I use the toe of the mini skew and just go really really slow. that last 1/16 of an inch is moving very slowly if you look at the surface speed of a spindle that size so the only way to get a clean cut without leaving a torn tenon is to go slow.
Check into the Bonnie Klein videos, which are available through many turning clubs. While these are pretty old, and I hope Bonnie will re-do them one day, they still present very solid, well-explained information on using small lathes to make small things. You can make smaller turnings than she shows with all the same glue-block methods, though you might want a set of magnifying glasses. You can also explore the wonderful realm of miniatures by turning all manner of hard nuts and seeds -- even nutmeg ! Angelo Iafrate has made some beautiful things out of various palm nuts, etc... For micro-turnings, you may have to be inventive, creative, or just a little bit nuts ! I'd ask John Lucas about that part ... ;^)
>Another way to "chuck \" small pieces of wood is to turn a Morse taper on it that matches your lathe's shaft and drive the piece directly into the shaft. I do this with "Icicles" for ornaments, but you can use it for any small item you can think of.
You can take a small scrap piece and turn a taper on it and mount it into the shaft and turn it into a "faceplate". I have a number of these that I glue small pieces of wood to with CA glue and then turn the small block. At the end, I either turn part of the faceplate away to free the turning or if the block was big enough I turn part of it away. Then I true up the face plate and use it again.
You can make a pattern for the Morse taper by taking your existing drive spur and laying it on a scrap of wood and fastening two small pieces of wood on either side, leaving a tapered slot when the center is removed. Then you turn your piece until it fits in the slot and see if it will drive into the shaft of your lathe.
>I use the smallest jaws I have for my chuck. My tools are the small Kelton set but for very small HFs I made a set of tools out of picks I got at Northern Tool.
A hent for polishing the minis is don't part the off until they are buffed. The base that was in the chuck gives you something to hold on to. After buffing just part off the base.
