A55 Smoothing Plane
easy question
easy question
easy question
eliot d
>What is the kind of wire that David Ellsworth and others use to make those low-tech wall thickness gauges for hollow vessels?
Re: easy question
Re: easy question
Ed Karch
>It is called coathanger wire Elliot I can bring you a sample at the meeting on Sat :o)
Re: easy question
Re: I use old fashioned galvanized clothline wire.
JamieDonaldson
Re: easy question
Re: easy question
robo hippy
>I use pieces of the wire they run along the bottom of a chain link fence.
robo hippy
Re: easy question
Re: easy question *LINK*
Ken Grunke from SW WI
>I like soft copper tubing, instead of wire. I have several calipers made from 1/4" OD tubing which I salvaged from an old school building. Thicker and stiffer than coat hanger wire, but easier to bend.
AAW forum tip bendable calipers
Re: easy question
Re: easy question
Merv Graham
>Go to you nearest welding supply store and get a lenght of 3/16 copper coated welding rod.
Re: easy question
Steven Antonucci
I believe he referred to it as armature wire
steve antonucci
>I think it's used in modeling for sculpture. Any good stiff wire will do.
steve
Re: easy question
Re: easy question
eliot d
>Thanks all. I'll try either the tubing or the welding rod. (Ed; The trouble with coat hanger wire is that it's too springy to be of any use; that's why I posted my question.)
Re: easy question
Re: easy question
>I use copper "ground" wire. (suggested by David himself) Either number 4 or 6. They have it at any of the Borgs or electrical supply house. They may give you short scraps if they have any. (ground wires must be continuous without splices, so pieces less than about ten feet long are not very salable.) I find the copper is stiff enough but soft enough to not be too springy. You can cut it easily with any type of nippers and I file the ends smooth and slightly rounded. (very easy on the copper) I have made a bunch in all sorts of weird shapes to measure side and bottom thickness no mater what shape the vessel is.
Re: easy question
Re: easy question
eliot d
>Bary. Thanks. You know, I think I'm going to go out and get some of the ground wire you have suggested. I happened to have some oil heating guys out to the house yesterday doing some work and I salvaged some 3/16 inch copper tubing, which is what some others have suggested. But after I bent it into shape, I found that it was still too springy. So I want to give your advice a try.
Re: easy question
Leo Van Der Loo
To soften up the copper wire or tubing,
Leo Van Der Loo
>heat it up to red hot, then throw it in water, it'll be as soft as possible.
Have fun and take care
Leo Van Der Loo
Re: easy question
Re: To soften up the copper wire or tubing,
eliot d
>Wow.Wouldn't have thought of that! Yesterday I figured out that using some heavy soldering wire would work well. I think I'll try your scheme just to see how it works out.
Believe it or not, now that I have more or less, with everyone's help, figured out the right wire, I find that it's not all that easy to use this method. My current vessel is one of those flat, "river stone", hollow forms about 3 inches deep and 8 inches wide, and I just can't seem to get the hang of getting a feel for the thickness. The wire still seems to spring around too much, and the flat geometry of the form presents a problem in forming the right curve to the wire..
Re: easy question
Leo Van Der Loo
Eliot, one other thing, don't try to have the wire
Leo Van Der Loo
>tight against the wood on both sides, have a gap, than look how much the gap gets smaller or larger when you slide the wire along, it'll show the thickness changes and how and where there are changing.
For your flat river stone shape you need to make a couple of them or else there's going to be an angle between the tips and you are not going to be measuring square to the wall, same problem as you get with the laser when using that for hollowing help.
Leo Van Der Loo
