Vinces sanding discs
robo hippy
>Thanks to a post here about a month ago, I got a bunch of sanding discs from Vince (Vinceswoodnwonders). For the first test, I sanded out 2 Myrtle bowls (14 and 12 inch diameter), and the discs still felt like new. Well, I thought, maybe this is just me. I next gave some to my friend Larry who is a production turner. He has turned his 'Grimple trays' (about a 6 inch myrtle bowl) to the tune of 600 to 800 per year for the last 11 or so years, and knows exactly how much time each step takes. His responce was that these discs last twice as long as his other discs. I have been using the red aluminum oxide discs that I punch from rolls that I got from Klingspor. I am switching. I just finished about 15 more large bowls, and they still seem to way out last whatever I have used before. This isn't any kind of advertisement, I am just sharing a discovery (pun intended) that I made, and now I know why you were ranting about how good his discs are.
robo hippy
Re: Vinces sanding discs
>Thanks I needed new sanding discs and thought about trying out Vince's. I'll give him a call tomorrow.
Re: I'll drink to that! OOooppps, wrong...
JamieDonaldson
>... answer, but I agree with what you said!
Cyril Griesbach
>Robo, are you using a firm or soft pad with those discs and what size?
Cyril
robo hippy
>About 95% of the time I use 3 inch discs, and a soft pad. Most of my bowls are 6 inch and up and 3 inch pads will sand a lot faster than 2 inch pads. I do ocasionally use 2 inch discs. I never found the need for the firm pads. They don't conform to the inside of the bowl, but work fine for the outside. You can use them in the inside, but most of the time you will just be contacting on the edge of the disc, and not using most of the pad surface. I just don't want to change the pad every time I go from inside to outside, and back. Vinces soft pads are a little bit firmer than the soft pads that I got from Craft Supplies which I think is a good thing.
robo hippy
