We value your privacy.
>Has anyone had experience cutting and turning ironwood? I was just given several fairly large pieces. Do I need to cut them on a metal cutting bandsaw or can I do it with a wood cutting blade? Can it be turned using standard bowl gouges or does it need to be scraped with a HSS cutter? Thanks for any input you can give me.
I agree completely with Joel -- no worries cutting it with normal woodworking tool, and it turns fine with HSS gouges. While it does scrape well, you should get very nice, fine shavings off a sharp tool with good cutting technique.
Just for fun, though, you should consider that there are as many "ironwoods" as there are regions of the earth.
In the Northeast, (as well as in Audobon guides, etc...) the term "ironwood" refers to Eastern Hophornbeam (Ostrya virginiana), which is a small to medium tree that can be over 100 years old, and still 5" in diameter. I have seen them as big as about 20-22" at the base if they grew with lots of light, or in the middle of a meadow. But then there's Desert Ironwood, or "Ironwood Tree" (Olnya tesota), that apparently grows only in the Sonoran desert; Pau Ferro (there are at least 2 of these, one from South America, and another from Africa),; and "ironwood" also is sometimes used to describe "Hornbeam" (literally, "tough wood"), a.k.a. "Musclewood" (Carpinus carolinia), which is also nicknamed "blue beech". So, not to be too much of a nerd about it, it seems that the toughest and gnarliest wood that grows in a region is nicknamed "ironwood" to indicate its surly nature, difficulty in sawing or nailing, etc...
I use Eastern Hophornbeam often, both green and dry, and it is a pleasure to turn with sharp tools. It takes detail very well, has a nice color, extremely fine grain, and polishes up very nicely. Due to its high density it does take a long time to air dry, however, so it can crack on you if you assume its dry and bring it into the house before its time. So far I have not had much success with microwave drying. I tend to get a dry scratchy throat from turning it, and a funny metallic taste in the back of my mouth and throat, so some percentage of us must have allergic reactions to it. I'd take Joel's advice and wear a mask just to be sure.
>If it is Desert Ironwood, your bandsaw will cut it with no problems. I use M2 bowl gouges when turning. Just have to sharpen more often. It's well worth the effort because it polishes up real nice and has great chatoyance.
>I have some pieces of ironwood from the Florida keys. This wood was from dead trees that we salvaged some 25 years ago. It is known as Black Ironwood (Krugiodendron ferreum). It is extremely dense (dried wood denser than water) turns beautifully but tends to chatter chip (face turning with poor support causes micro pull outs). Below is a bowl that we use regularly (looks like it needs to be cleaned). It measures 3-3/4 x 1-1/4 and the holes were filled with clear epoxy before turning.
