Delta Midi newbie question
Steve Kubien
Steve Kubien
>My again,
Assuming I find out that turning is something I want to pursue (which I suspect it is), what are the thoughts and opinions on the Delta Midi lathe? The Borg around here just started carrying them and for $300 Cdn I can get the machine and a 5 piece starter tool set. Is this an ok deal? Is this lathe worth it or should I look toward the General Midi or the small Jet?
Thanks again,
Steve Kubien
Re: Delta Midi newbie question
Jim Swank
>I've got the Delta midi - a nice little lathe except for the plastic handles that want to break off. They may have upgraded those since I bought mine. See if you can find the Jet with variable speed for a little less. You'll like variable speed MUCH better than changing belts.
>You said "Assuming I find out that turning is something I want to pursue (which I suspect it is), what are the thoughts and opinions on the Delta Midi lathe? The Borg around here just started carrying them and for $300 Cdn I can get the machine and a 5 piece starter tool set. Is this an ok deal? Is this lathe worth it or should I look toward the General Midi or the small Jet?"
I recently had an opportunity to see the newer General Midi lathe demonstrated (25-200, 3/4 hp, variable speed). I think they call it the "Maxi-lathe". That is a sweet little machine. The 3/4 hp gives it a lot of power and you can turn up to 12" in diameter. I've seen and used the Jet VS minis and I like them a lot. Delta, IMHO, has been going downhill in terms of quality and service since their takeover.
All that being said, you're going to have to make the call. The Jet Minis are a known "standard". They are limited in size to 10" for bowls (as are the Deltas). They have an excellent resale value and a lot of accessories available. People often start with a Jet Mini and keep them when they get a larger lathe. The new General has a little more capacity (12") and a little more hp (3/4 vs 1/2). I just wish the demonstator would have let me try it out :).
The Delta may be a good deal for you now. I started with a larger Delta (46-715) and bought a Jet 1642 EVS about 1 1/2 years later.
>Steve woodcraft has the Rikon on sale right now for $219. I would go for that. It is in the same class as the Delta if not better.
Mike Brazeau
>Steve - you can pick up a General Maxi for $299 also, no tool set. Jet is not available in Canada any longer, variable speed never really was. If you live near the border, the variable speed Jet converted to Cdn is about that amount, perhaps a few bucks more. Rockler in Buffalo has them at $269 until this weekend someone posted at CWW.com . I have a Delta I bought to take to the cottage and I only paid $259 three years ago. If buying now and spending $300, I would go for the Maxi. Rona are supposedly no longer going to carry the Maxi and clearing where they have them in stock, which is in the larger stores I believe. General also have a new variable speed version of the maxi, with swivel headstock and outboard extension for the banjo, but is $639 Cdn (House of Tools price).
Mike
E Tabachek
>hello JL Where did you see the General demoed? How noisey? Was it smooth running? How is the quality of the machining and finishing on the lathe? Did the demoer say when the macine will be going out to the dealers?
Ed.
Leo Van Der Loo
Re: Delta Midi newbie question *LINK*
Leo Van Der Loo
>Steve you could have bought the Delta at the Woodstock woodshow last week for $279.- including the extension, if you wait till Feb2-4 in Chatham or a week later in London at those woodshows they probably will have deals on again, they did last year.
As for the Delta Midi, it is basically the same late as the Turncrafter or the Jet, same everything but the color, and switch, door position. They are good little lathes for the money, the Delta at HD has the metal handlesand you do get a set of hss mini tools with it, for $299.-, the Jet at rockler cost $280.- us = to $315.-cnd the var, speed Jet is $375.-us = $425.-cnd plus shipping maybe, the Turncrafter at Penn State is $180.-us =$205.-cnd plus shipping so take your pick, as for the General International mini and also the King Canada one, these lathes are not the same as the Delta, the biggest difference is the headstock bearings being even closer together than with the Delt/jet, as they have the belt pulley sitting behind the headstock, needed clearance in the bearings accentuate this by the close set bearings for more spindle play and vibration, and I would prefer the Delta/jet over the General International, as for the Rockler price see link. sorry for this long ramble.
Have fun and take care
Leo Van Der Loo
http://www.rockler.com/product.cfm?page=2441
Re: Redmond & Son
>They had a open house. I went to look at the Steel City stuff. I'm in the market for a cabinet saw and a big jointer. I poked around the lathes. I didn't ask about when it would be released as I'm not in the market for a Midi (yet). I think it is supposed to be released this month. As far as machining and finish? On par with the usual General equipment (pretty good).
I was impressed with the thought of 3/4 hp on a "mini". I didn't see him do the outboard thing, only inboard.
Jerry Whitaker
>I ONCE had a Delta but now have a VS Jet Mini and in my opinion, there is no comparison. Nearly every Delta I have ever seen has new homemade handles to replace the cheesey originals. The best thing about the Delta is that the door for changing the belts are up front but really not a big deal. Just bought a 6-speed Jet Mini from Woodcraft at the SWAT Symposium for a friend for $219.00. I don't want to get into heavy brand bashing but you will not be unhappy with the 6-speed or VS Mini Jet.
Delta is now comparible to Craftsmen.
Norm Smith in Nova Scotia
In defense of.....
Rick Davenport
>the lowly Delta Midi.
I bought one a few years back for the sames reasons you are looking into it.
It was the best deal at the time - a special price plus a free bed extension.
I used it exclusively for my first 18 months of turning.
I never had a problem, the (metal) handles did not fall off and I still use it today for quick jam chucks and other odds and ends.
True, it doesn't have variable speed, but that was no big deal since the only time I changed speeds was at the beginning of each project and it only takes 15 seconds anyway.
I've since played on a Jet mini and the only difference I could tell was the VS.
I now own a PM3520 and enjoy the heck out of it.
But the midi is what got me started and I will fondly keep it.
It's not a piece of crap as some have said.
It's a good starter lathe that may or may not lead to better things.
Rick
"Life shouldn't be dull."
Bruce Wiseman
>Well, I certainly don't want to start a flame war, so if you like your Jet VS lathe, good for you! But I don't like them. They lack power (torque) in the low speeds. The ones I have used can be stopped with your hand if you have any kind of load on it. I've turned some bowl stuff on the belt drive Jet that was at size capacity and maybe beyound what weight the thing is engineered for. I don't think you could do that on the VS. Just my thoughts...
