Re: Drying question from a newbie
Bill Howatt
>Allen is right about cutting the pith out of it to reduce the chance of cracking - note that I said reduce not eliminate.
A couple of coats of old latex paint will help reduce the cracking but IMO Anchorseal is much better. With either coating it is a good idea to get the wood roughed down to suitable drying shape ASAP. There is a lot of variation in cracking tendencies. Depends on the type of wood, its history, the environment it's placed in after sealing etc. Fruitwoods like apple crack very easily, maple is probably about average.
If you are making a bowl the general rule is to rough the bowl down to a uniform wall thickness of about 10% the diameter of the bowl. This will let it dry without creating excessive stress and there will be enough wall thickness to allow you to turn the dried bowl back to round since it will be oval when dried.
Spindle turning, where the grain of the wood runs parallel to the bed is less likely to crack but it can happen. Bowl turners typically like turning green while spindle work is usually done dry. This is just a general statement and not everybody works that way.
After you have you green bowl or whatever roughed, put it in a paper bag and stick it in a cool dry place so it can dry slowly. After it is dry, typically a few months, you can then finish it. There are ways of speeding up the drying process like microwaving, kilns,alchohol soaks, liquid-dishwashing soap soaks. I just let them dry in bags often with a handful of the shavings included to slow the process a bit.
While I am rambling, some people coat the roughed bowl in Anchorseal on the end-grain or the whole bowl, or just the inner or outer end-grain. This does slow the drying process and does make cracking even less likely. I only do it if I have some nice piece of wood I really want to reduce the chance of cracking.
The proper way of roughing and drying is a topic that can produce as many theories as there are turners.
Bill
