wood type
Tony Zaffuto
>For a newbie, what woods would you suggest for learning?
wood type
Tony Zaffuto
Re: wood type
>Anything free. I turned a lot of firewood when I started because I didn't have a chain saw or a good bandsaw. I could cut that stuff down to size with a bow saw and rough shape it with a hatchet. Limbs are good to practice with but will usually crack unless you learn to work with green wood and hollow turn it or turn it very thin. I make natural edge bowls and hollow ornaments from limb stock.
As far as species it's hard to beat maple. It's easy to find. Turns great wet or dry and finishes well. If your lucky enough to find birdseye or curly maple you have something really nice. It stores well without checking as bad as some woods and if you catch it before it rots is spalts nicely and people just love spalted wood.
Re: Spindle or bowl?
>For spindles, anything cheap. Fir, pine and poplar for example. Graduate to maple and oak and progress to others. For bowls - anything free or inexpensive. With all the development, you can always find reasonable wood.
Tony Zaffuto
>Thanks for the responses. I got an armload of 5" X 5" x 2'+ redwood. I've played a little with it, turned my first bowl & I don't like it! Fuzzies all over! I've played a bit with cherry & turning some tool handles and the cherry turns very nicely.
Now the eternal question remains--are the fuzzies the result of a novice sharpening job or because of the wood species?
Probably both
Dave Belser
>Early on in my turning I got a hold of some Fir - that stuff is virtually impossible to turn cleanly. That fact that my sharpening skills needed work, most certainly aggraevated the situation. I imagine that dry redwood is somewhat like fir. There was a beautiful piece at the 20 year retrospective show in Louisville done out of Fir. In the description the artist described Fir as concrete and styrofoam.
>Many of the soft woods (fir, pine, redwood) give you "fuzzies". Poplar and holly do also. Sharpening is one answer, so is shear scraping. Me, I use "shaping paper" (sand paper) along with shear scraping. I sometimes do leg mock-ups in pine and fir to get angles and proportions. They are a lot cheaper than maple :).
Re: redwood
Thad
>My first bowl was out of redwood, required alot of sanding to get rid of the fuzzies but it was something I had to do b/c my FIL said he didn't think it would work. I don't plan on trying it again any time soon though.
Here in central GA there are several developments going up in pecan orchards, so I've been turning alot of that as it is just being burned up on the job sites. I've found it to turn easy and require much less work for a good finish than the redwood did.
Just my rookie opinion,
Thad (turning 6 months)
Re: redwood
Allen Neighbors
>Thad, if you're turning Pecancrete, and not having a problem with it, you're doing okay... :o) Pat yourself on the back.
Allen
>Tony Very sharp tools and a slow feeding rate of the tool will help you cut withough fuzzies on Redwood. You might even try spraying it with water. I turn redwood lamps made out of 30 year old ballisters that came off one of our dorms. I have some problems with tearout or little fuzzies on the top of beads. I just take a few more passes with a very sharp tool and light cuts. That usually solves the problem.
Bob Rosand uses a coat of fresh sanding sealer before the final cut. This helps the tool cut cleanly.
