We value your privacy.
>I believe this is elm. I got a big catch in turning the bowl to shape and at that time I decided I hadn't tryed texturing yet. So, this is the finished product. I have some strey paint marks on the bowl and I was wondering if anybody had any suggestions on how to get them out. Thanks for looking. Sorry for the poor picture.
>Blake, you keep showing some great improvement and insight into this obsession. A little more light would help a lot with the picture. Your piece is great though, at least as well as I can see it.
>Your pieces are looking great. I agree with REVdoug It's hard to see the details. The photo needs to be brighter. If your setting the exposure on what your camera meter says is accurate trying over exposing slightly. If your using the camera on auto settings see if it has over/under or +/- exposure overrides. If it does use the + setting and go one or two steps on the plus side.
It also looks like you might be using tungsten lights the camera isn't adjusting far enough. Try using the tungsten or indoor white balance setting.
I assume you finished the piece and then painted it. If that's the case you have a couple of options either of which might cause problems with the finish. That's one of the reasons I like lacquer or oil finishes. They are easily repairable.
You may be able to scrape the paint off. This is a technique we used to use in photography to get dark spots off of prints. We used a sharp piece of acrylic plastic and gently scraped at the area until it was gone or reduced enough to blend in with the background. I have also used the tip of a sharp exacto knife to do the same. Use patience and take off a little at a time. This may leave a dull area but you might be able to rubb it out and or apply more finish over this area. The trick is to go through the paint but not the finish.
A more drastic approach that I know will remove the paint but may also remove the finish is TSP. Trisodium Phosphate. It's sold in hardware and paint stores as a cleaner. It will actually eat all the paint off of a dried paint brush. If you applied it in small amounts using a small paint brush it might soften the paint enough to remove it. I've taken spilled paint off of a table with it and only had minor damage to the finish. Use gloves and all the usual safety equipment. This isn't dangerous stuff but it can burn you.
The simplest approach might be to just use a small piece of steel wool and go at it. It will take some work but you should be able to remove the paint. You will probably rub a dull spot or even rub through the finish but it will take the paint off. An Ink eraser might also work. They are pretty abrasive but it depends on how much paint is there and how thick it is.
>... to the raw wood without finish it probably soaked in enough that you won't be able to easily remove it. Very interesting to watch your progression in designing after turning- you must have a real artist's mentality, so keep on keepin' on!
