Shedua Box
Mike Stafford
>Here is a box 2 3/4" tall and 3 1/2" in diameter turned from some shedua with wonderful curl that I am unable to capture in a photo. Maybe someone can help me with that... I just love the way shedua polishes up....
Shedua Box
Mike Stafford
Shedua Box: Photo Question
Mike Stafford
>Another photo question associated with the photo above. Why does the box appear to have red in it when I photograph it from above? The wood has no reddish tones....
Re: Shedua Box
Bill Stehman
>Mike,
Beautiful wood and nice box... sure couldn't hep with photos but some will cime in.
Re: Shedua Box
gil jones
>Mike,
I do not know about the photo colors, but that little box sure is pretty, and well made. Is Shedua a local wood?
Re: Shedua Box
Mike Stafford
>Gil, shedua is local for folks in certain parts of Africa. LOL! It is also known as African walnut. I was given this wood as a gift by my son and wife. Thanks for the comments.
Re: Really pretty and really nice wood..
>Darn! Now I have to go find some.
Re: Shedua Box: Photo Question
bushmanpilot@yahoo.com
>You used two lights. The highlight on the left side of the piece is probably from a halogen light with a warm color temperature of about 3200 degrees Kelvin. The center highlight is probably from the on-camera flash which is rather bluish at a temperature of 6500 deg. Kelvin. Note the blue shadow to the right and the orangish-yellowish shadow to the left of the piece. That's where the "red" is coming from�the halogen light.
Ron McKinley
>Forgot to mention. That is beautiful work with beautiful wood! ...Ron
Re: Shedua Box
Allen Neighbors
>Mike, that little box is gorgeous. Looks as if the lid really fits well, too.
I'm not positive about the reddish glow, unless you have something reddish close by that could be reflected in it. If the above isn't true, I would say it's the chatoyance of the wood. It could have something to do with reflectance within the finish and the surface of the wood itself.
As far as capturing the curl, I don't know what your photographic setup is, so I couldn't begin to tell you for certain. But I think more evenly diffused light will bring out most grain.
Maybe John or Jamie will come on board after while.
Allen
Re: Shedua Box
>Mike That's a very nice box. It sort of looks like a fat guys face with a hat on top. I like the form a lot. I was wondering what it would look like with a taller lid. Probably not good but I have a vivid imagination and I've never tried a tall lid on a small box.
Mike Stafford
>Well, Ron, you got my set up pegged perfectly. Were you peeking in the window? Is there a way to correct it without going to a lot of expense?
Re: Shedua Box: Photo Question - took the liberty
Ed
>Hope you don't mind me adjusting your photo, but I photoshopped out some of the red. Is this more what you really see?
Don't use a flash for photographing your turnings. A tripod, a sufficiently long exposure and soft even lighting will give you the best results. All lighting should be the same and indirect if possible. You'll get nice highlights on your finish without the burned out glare spots from a flash / direct light source.
Ed
Re: Shedua Box: Photo Question -oops!!
Ed
>Forgot the link to the picture in my last post. Sorry.
Ed
Ron McKinley
>Ed's suggestion is good. Use only one light source, say the halogen, with the camera on a tripod. Use white cardboard reflectors to open up the shadows from the one light. Position the light high and to the left of the camera and put reflectors on the right side of the object so that it will pick up the light and reflect on the shadow side. Also, since the exposure time will be long, use the self-timer on the camera to trip the shutter. If you do it with your finger it's going to be blurred from the movement of the camera as you click the shutter.
Hey, John Lucas is the expert here. Come on in John...........Ron
Mike Stafford
>Yes, Ed that is exactly what I see. It looks much better without the red don't you think? I understand that you used Photoshop to make that change but what specifically did you adjust to effect the change? I have another program that does similar photo manipulations but I am not sure where to make an adjustment suchas that.
Mike Stafford
>Thanks to everyone for the suggestions and help and nice comments...
Ed
>I used a mask to limit my adjustments to just the area shaded by the lid. I used a Selective Color adjustment layer and changed the color balance in the Red, Cyan, Blue and White bands. If you don't have photoshop then the previous probably doesn't help much. You might try and google "DP Review" and check out the "Retouching" forum. Helpful people that will likely be willing to give you tips on how to accomplish it with your software.
The easiest approach, if you still have the piece, would be to just shoot a new picture. Without the flash you would be much more likely to get the curl visible in the photo as well.
Ed
Re: The photo tips about ....
JamieDonaldson
>... not mixing different light sources were right on target. Try to diffuse the single light from the front side quarter by bouncing it off a large white surface like foamcore boards, and turn the flash off. Match camera color balance to source- easy to see by trial and error if your camera has such adjustable settings.
