A55 Smoothing Plane
Turning Wooden Rings #1
Brad Vietje
Brad Vietje
>My nephew is getting married next weekend, and since he seems to have allergic reactions to gold, silver, platinum, etc..., he asked me to turn him a wedding ring. I agreed, and set out to find suitable material from which to turn a prototype. Artificial ivory was out because he didn't want a white ring, so I suggested water buffalo horn, and thought I could find some celluloid "tortoise shell" or something similar. I turned a ring our of the water buffalo horn, which looked great, but I got the mostly black variety, and he didn't favor the dark color. I haven't found any tortoise shell stuff big enough, so he asked for Birdseye Maple.
I made a few Maple rings, and since I thought the wood was pretty light in color, I added Pink Ivory and Pau Fero for a little more color. I'm still looking for other materials to try that are available in appropriate sized pieces, and I have some real worries about the long-term durability of wood for a ring that isn't removed to wash dishes or shower. Advice will be welcomed.
Turning the rings is fun and pretty easy. I started between centers, and turned an approximate Morse taper by trial and error. This is tapped into the headstock spindle, then the outer profile is turned, and the inside bored out to the desired size. I saturated the wood with CA for strength, and sanded to 400 before parting off the rings. Then the rings are transferred to a friction chuck held in a scroll chuck, with careful sizing to get the right "grab" on the wood. Here the final shaping and snading are done, and application of any finish or polish. The process is shown in 3 photos, and the end result in the 4th.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Turning Wooden Rings #1
Brad Vietje
Re: Turning Wooden Rings #2
Brad Vietje
Brad Vietje
Re: Turning Wooden Rings #3
Brad Vietje
>Ring on friction chuck. I also used a friction chuck with a step narrower than the ring, so I could shape and finish one edge of the ring at a time.
Brad Vietje
Wedding Rings
Brad Vietje
>The finished prototypes...
Re: Wedding Rings
David Hammond, in Powder Springs GA
>Way cool Brad! I was just thinking about trying to turn a ring... Very cool, thanks for the info on how you did it.
David
Brad Vietje
Re: Wedding Rings
Brad Vietje
>Thanks David,
The sizing is the hard part, especially if the subject (victim ?) isn't at hand, so to speak. Fortunately, my nephew can wear my ring, and says it should be "just a bit smaller", so I could set calipers a little smaller than my own ring, and procede from there. A roll of 320 can be used to enlarge the ring after the fact, which could be done by the recipient, if necessary. There's probably no graceful way to make them smaller.
Safe spinning,
Brad Vietje
Newbury, VT
>Brad I would think it would be necessary to laminate the wood. You will have a very weak point on the side grain areas. I like your idea of using horn of some kind. The company that sells alternative Ivory has some other colors available. I would have to dig to find those but will be glad to do it if someone else doesn't have the souce handy. I've got to head off to work or I would do it now.
Brad Vietje
Re: Thanks, John !
Brad Vietje
>Thank you so much -- I appreciate any sources you can dig up.
I made them in end grain orientation hoping that would help avoid two weak spots, but they are still weaker than I would like.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Thanks, John ! *LINK*
>End grain will be weak all the way around. If you glue up the wood out of thin veneers you make yourself you won't see the joints. I made bracelets out of 5 layers of homemade veneer. They hold up really well. I would think a ring could be made the same way. Just rotate the grain 90 degrees for each layer.
Not sure if this is the place that advertises in the turning mags but may have some materials worth looking at.
http://www.constantines.com/browseproducts/Alternative-Ivory.html
Richard Allen
Re: Turning Wooden Rings #1 *LINK*
Richard Allen
>I would use stablized wood for the rings. There are bottle stopper blanks in a variety of stablized woods.
One of many sources of stablized blanks
What About Corian?
Barbara Gill, Remlik VA
John Kyler
>DITTO
I would also suggest the same.
Leppikallio
>I think I would go to extremes (and now when you have shown me the way I can finally give some nice surprise to my dear wife). How about stabilized and colored giraffe bone plates? Dirty expensive but if about 1/4 thick would be enough it would be probably nice material... Or mammoth ivory? Probably available closer to you somewhere but atleast Dick.biz sels those and much more...
http://www.dick.biz
Re: Sort of on that line...
>how about stone? I've seen carved stone stuff. I have seen some examples of turned stone. I don't know how it would work though.
Lan Brady
>Brad,
The rings are wonderful. Anyone would be proud to wear one. If you are looking for constant skin contact for the long run, most of the materials may present problems. I too have allergies to the metal metioned. The only solution for me was stainless steel.
Lan
Leslie S
>What about Truestone? I don't know if it would be strong enough but maybe worth a try.
Bob Fawcett
>Brad,
If he has an allergy to metals, does he also have an allergy to some wood species or other materials?
Just a thought.
Maybe some type of bone or horn material.
The link is a knifemaking supplier I have dealt with. They sell materials for knife handles that may work.
Jantz supply
Ian
>really cool looking rings, I had thought of trying the same thing using laminated veneers to solve the weakness problem and maybe add a little color style.
IAN
Brad Vietje
Thanks Everyone !
Brad Vietje
>Thanks to all for the helpful suggestions. I followed all the links and found some really nice materials, and some suppliers I had never heard of. I probably don't have time to get new stock before the actual wedding (next Saturday), but the groom is aware that a more permanent replacement may be needed. I may still see if I can get something sent express mail to make a few more rings before the big day.
Nonetheless, CA-stabilized wooden rings are fun to make, and can certainly be used as occasional use accessories, and I have discovered that the water buffalo horn turns and polishes quite nicely, though it is a little brittle. I may get some in the lighter color. For anyone interested in water buffalo and other horn material, check out the link to Universal Agencies (UAI).
Many thanks,
Brad Vietje
Newbury, VT
Brad Vietje
OOPS -- No Link...  *LINK*
Brad Vietje
Knife Supplies
Leo Van Der Loo
Leo Van Der Loo
>Hi Brad, I'm maybe a little late with my respond, but if you stay with the wooden rings, making them in 3 colors is maybe a nice way of getting the strength into your rings, it was/is sought after in europe, OK it's been a while since I looked for wedding bands, anyway here's a picture of one, and no it's not wood, just for the colors.
Have fun and take care
Leo Van Der Loo
Brad Vietje
Re: What About Corian?
Brad Vietje
>Thanks, Barbara. I did think of Corian or other plastic resin materials, but haven't found a color or pattern my nephew likes yet. Nice thing about these is that they come in handy 2" x 2" x 1/4" samples, which could make 3-4 rings. I've turned Corian before, and I think its just about ideal as far as toughness and water resistance goes.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Thanks Everyone !
B. Leathers
>Brad , Saw your post on ring making . You may also find insight into this by going to a website , " Artistree" wood art by Dale Randles . I stumbled across this while trying to get ideas of mounting small gems into turned craft . Best of Luck , B. Leathers
Jim
>Don't mean to take away from your awesome efforts, but you don't mention if he is allergic to Titanium....
http://www.boonerings.com/ makes many a custom Titanium band. I met Bruce the other day at a Penturners get together in Roswell, and he's a heck of a guy. I'll bet he could whip something up out of just about any other material also.
Jim
>Actually Titanium is very inert, and usually you don't get allergic reactions to it... Boone will do custom wood inlays as well...
