Veritas - Innovation in Tools
Well, I have a problem…
Rod Peterson -- Ormond Beach
>Today, I attacked the lathe area of the shop (I'm at the tail end of a major house remodel, and the shop has been the last thing to get attention), and took advantage of being able to get it out in the open to do a little turning of a chunk of live oak from the tree I cut down a couple of weeks ago (story posted in the Messages Board and viewable here, if you're interested).
I think this is the first large piece of wet wood I've ever turned, certainly on my own lathe, and all the video tutoring of Grumbine, Marks, Yoder, and Hout, plus the worded wisdom of the folks here helped things progress fairly smoothly. It was certainly enjoyable. I got the blank roughed smooth, cut the recess for the chuck, turned the blank around and got it rough hollowed, then put it in a paper bag for refinement later on.
When I switched to the chuck (Vicmarc 100) I noticed things weren't as true as when I was on the faceplate, but I attributed that to previous experiences I've had. However, after I was done with the wet blank, I took a small piece I'd had in the chuck previously and chucked it up and it wasn't round either. It was then that I noticed that the whole chuck seemed to be wobbling slightly.
Okay, background. This lathe is a Delta 46-700 (12", Reeves drive, circa late '90s, early aughts vintage, I imagine) that I bought used from Woodcraft a year or so ago. The small piece referred to above had been turned on my Jet Mini. Among the first things I did was pull the chuck and put in a spur center. The point never wobbled. I screwed on one of my faceplates, and there seems to be some wobble there. The clincher, however, was when I put the chuck (with the small piece still attached) back on the Jet and hit the switch. Ran true as teenage love (whatever that means—I couldn't come up with a good simile).
So, my conclusion is that while the Delta arbor is true at the Morse taper, the threaded portion is somehow jimmied up. I even filed the face of the nut to true it up to no avail. I think I can discount the Vicmarc as the problem since it ran right on the Jet.
Is it possible that I messed up the arbor when I had the rough blank on? I had the lathe on the lowest possible speed, which, unfortunately, with the Reeves drive is only about 500 RPM. The fact that the spur center still runs true seems to counter that idea. Anyone have any opinions?
I think I have to order a replacement arbor.
Rod
Re: Well, I have a problem…
Leo Van Der Loo
Re: Well, I have a problem�
Leo Van Der Loo
>Rod there's a good chance that there's nothing wrong with the lathe or the chuck, but that the treaded end of the lathe shaft is longer than the chuck can accommodate, or that the treaded part is not long enough, in which case all you need is a filler ring that fits the shaft and is thick enough to fill that gab.
The back of your chuck should fit tight against the shoulder on your lathe shaft.
Hope this is all you need.
Have fun and take care
Leo Van Der Loo
Mike Nelson
>Rod, if a morse center runs true, sounds like nothing bent. I would put the tool rest just touching the threads turn it by hand, if you hear itermitant scraping, new shaft. I would also put something heavy on and check the bearings for noise and play, they might need replacing after 25 yrs or so.
Bob Elliott
>Rod,
You say you bought this lathe from Woodcraft. Would it be the one in Casselberry? If so, I have a something to tell you about a 12" Delta that used to be there.
I have taught classes there over the years and there was a grey reeves drive Delta with a problem. I had determined that the Delta in the class room had a bent shaft and pointed it out to two consecutive owners of that store. I even went so far as to put a mark on that lathe. It might have been a yellow lumber crayon that I used. Look underneath the plastic cover & see if it's there.
Let us know.
robo hippy
>Check to see if the jaw set screws on the chuck are tight. I have had this problem a few times where the screws work their way loose. Things would run true for a while, then I would have problems with reverse mounting my bowls and they would be more off than acceptable. Turns out it was the jaws being loose.
robo hippy
Yes!!!
>It was the Woodcraft in Casselberry, and on the bottom of the front cover (not inside) is a big, yellow, “B”. Private email to follow.
I'll keep you all apprised when a solution develops.
Rod
Re: private email
>It bounced due to anti-spam. I don't respond to those. I would like to have discussed this with you.
Rod
Re: private email
Bob Elliott
>Rod,
You are now unblocked and I have read & responded to your e-mail.
Thanks.__________
