Poison Ivy/Oak/Sumack and turning
Craig Daymon
>Over the weekend a friend and I were offered whatever we wanted of a Locust tree that had been brought down. When I got there, I found the reason it was brought down was because poison ivy/oak/sumack (the black hairy vine stuff) was growing straight up through the pith. I'm very allergic to the stuff, so I declined and kept a safe distance while it was being cut. I did help where I thought I could and managed to escape without any itching.
Two questions I have are:
1) Anyone know if the poison whatever grows up through the center of a tree like this if the oils will permeate the wood, making it dangerous for someone with a sensitivity to it to turn?
2) Any methods for safely working with wood that has obviously had a close relationship with one of the poison ivy varieties? I haven't had any issues up to this point, but I've never seen anything so thoroughly infected as this tree.
Thanks,
Craig
Re: Poison Ivy/Oak/Sumack and turning
Re: Run away from it!
>The "active" ingredient of poison ivy/sumac is urushiol. Somewhat polar head group with a hydrocarbon tail. It's a heptadecyl catechol. A rather non-volatile oil. It can diffuse or be carried into wood pores. You can "rinse" it out with isopropyl alcohol, but why bother. More trouble than it's worth.
Ric Taylor
Ric Taylor
>There is too much good wood out there, don't waste any time on bad wood.
Ric
adrien
>How on earth did the vine manage to grow in the center of the tree?!
This makes no sense. PI is usually on the bark, gets to be 3-4" in diameter when full grown. But for it to be INSIDE a tree is certainly counterintuitive.
BJ
>There are several items available through most drug stores that seem to work for me anytime I either am exposed, think I may be exposed, or have been exposed to poison ivy or related. The first is a liquid soap called "Tech Nu" used after possible exposure and the other is a barrier creme made by the same company as Tech Nu. They also make a product that is supposed to be real good in the event the other products wasn't used again by the same manufacturer runs about 35 or 40 per small tube, can't tell you if that is effective or not since everytime I had it that bad had to go to the Dr. anyhow. I also use these products in the event I am around certain toxic woods (which ones, the one that breaks you out in a bad case of contact dermatitis,it my case Rengus, Cocobolo, Morodillo/Santos Rosewood, and certain others.
Craig Daymon
>We thought it was pretty interesting as well. Additionally, the tree was still quite alive when it came down. It was one solid, hairy vine of poison ivy right up the middle of the tree. Probably about 1.5" in diameter.
I'll steer clear. I didn't bring any home from this and I show no signs of contact, which I know I would by now. It seemed like it would be drawn up into the wood running up the center like that. I'll let my friend know it's not worth the effort. Shame, it was the first piece he's gotten big enough to justify turning outboard.
Thanks for all the advice (and more chemistry than I've had in years).
-Craig
