Re: Transferring images to burn,,,
Dick Anderson
>Devon:
Transfer of patterns onto wood for pyrography can be dne several ways. Copying can be done using graphite paper (specifically for transfer to wood) and tracing the image to the wood. Don't use blue carbon paper as the blue color can not be easily removed.
Othere metods include heat transfer and chemical transfer. With either of these methods the transfer must be made from a laser or xerox copy and not an ink-jet copy. Only the toner from the laser or xerox will transfer. In using heat transfer it is easy to overheat and scorch the wood, so care must be used. The chemical copying (again only laser or xerox) is done with acetone or xylene. The prismacolor clear blender pen also works.
Although I have used all these methods, most of the transfering I have done was by using graphite paper. Transfering from a flat piece of paper onto a curved surface will present a challenge. Tape the graphite paper and image paper separately and in a manner that part of the paper can be lifted up to view the work in progress and tomake adjustments as necessary.
Dick
