We value your privacy.
>Would anyone care to share any recipes they may have for a soft (or medium hard) paste wax that I can make here at the house? My line of thinking is perhaps a bit of a niche market for craft shows. A smallish lidded box with a homemade furniture wax inside. Oils could be added for scent (for instance, an attractive box on the nightstand with a lavender and chamomile scented wax to polish the nightstands to give the room a relaxing smell, citrus for kitchen, etc...). Any thoughts or feedback on the idea also?
>I've never heard of a need for such a thing but go for it. The only other thing that hit my mind was making a lidded box that would hold a can of commercial paste wax. Good luck with your endeavor.
I cook up a paste wax for my salad bowls from mineral and parafin plus a little tint depending on the wood. For cherry I add a bit of red candle, brown for walnut tan for maple. Heat up the oil over an electric hot plate, then add wax, and simmer until the wax has "dissolved." Pour out into 1-2 oz plastic cups. Doesn't take much wax to gel the oil. You can get chunk carnauba for some shine as well. Never tried scented oils.
>I like carnuba (about 50%) and beewax (about 50%). Melt and add some mineral oil to gel it up. I don't think it'd work for cars, but it sure works for wood. Vary the formula for softer or harder. More carnuba = harder, more beeswax = softer.
>Actually, there is a furniture wax out there somewhere that is lavendar scented. Might do a Google on it. Might be a good reference. Or maybe it was someone on Badger Pond and/or here that made it? Most paste wax is solvent based. Seems like it may be hard to overcome the smell of the solvent and the evaporation if it is not sealed real well.
>This is something that I have thought of doing, but really don't want to take on another side job. I did hear that the oil to wax ratio was about 6 to 1, but you may have to experiment. For bowls I use Mike Mahoney's products, for furniture I use Butcher's Wax (mineral spirits, turpentine, carnuba and other waxes).
>Thank you all for the recipes and idea feedback. I thought of the idea when I saw Richard Raffan used a turned box to keep his wax and oil (peanut and mineral oils) in some boxes he turned. I figured that while I hadn't seen a need, why not try to suggest a need that no one knew they had :-). It would be an impulse buy for sure but I thought the idea of having and attractive box with the wax at hand would be convenient (for caring for the furniture) and maybe add a little to the desire to purchase. And there is the aromatherapy side of it that will play off the ideas that made the candle industry go nuts (even if it is a little new agey) :-).
>Mike, I've made my own wax several times. I own a few cans of the smelliest stuff in the universe, too. :o(
Best I've ever made was using Odorless Turpentine as a base,(forget the actual name of the stuff) of which, the amount used determines the softness of the mixture. I mix about (close counts... never had perfect measurements) 50% Carnauba Flakes (for the durability of the wax coating.. measurement doesn't change like the others); 35% Beeswax for non-slipping wax, and 15% paraffin, which makes it slicker (but harder to buff).
(switch amounts between beeswax and the paraffin... more beeswax makes it not as slick, which is good for bed ways. More paraffin makes it slicker which is good for saw tables, jointers and planers)
The formulation with less paraffin, is really good for bare wood.
I haven't done this for several years, so my memory isn't too good.
I do know that the safest way to melt it all together is on a double boiler. Remelt, adding more of the base, if it sets up too hard when cooled.
Hope this helps you with a start, anyway. You can add different scents, for the aroma of your choice, as long as you stay away from stinky turpentine, or too much naptha. :o)
I do not make a lot at a time, but I make my own paste wax fairly often. I do not like the solvents in most commercial ones.
First, wax and oil do not "mix" in the sense that wax does not disolve i n oil, hense the solvents. So we make a suspension of wax in oil. Second, I only like to use edible products for safety reasons.
So I start with a mix of 50/50 vegetable and mineral oil. Then I put in a small bottle a piece of beeswax. Others can be used or mixed but this is my formula. I melt the wax in a baby bottle warmer. If you are going to melt wax over open heat sources, do not stand too near and keep a fire extinguisher handy. Once the wax is melted I add the oil mixture about 5:1, reheat and stir. You should get a well mixed suspension very easily. If it is too thick, reheat and add more oil, too soft reheat and add more wax.
One of these days I will get a better explanation up on the web site.
