Resin Push Pumps?
>I'm looking for a source for dispenser pumps for 1-pint and 1-quart epoxy resin and hardener. Thus far I've only found them to fit 1 gal. containers and dispense 2-6oz at a time.
TIA
Resin Push Pumps?
TIA
I've never found anything that small.
Bert Workman
>I have used the big gallon sized ones a time or two and they worked great on the big projects.
For the small stuff I've always ended up with small cups - waxed paper with graduated markings on the side. These were about 2 oz in size and were great for small quantities. Not as handy as a pump would be because you still have to poor it out and drip it all over...exacly what I'm sure you are trying to avoid.
On one occation I stole the little medicine cup off the the children's triaminic bottle - the wife didn't think too much of that one :)
The last several times I'm used the two part epoxy I just purchased the double barreled syringe from Home Depot. I loved these because you just squirt out what you needed and save the rest without too much fuss.
Good luck.
Bert
Re: Resin Push Pumps?
Hooligan
>Mark, I have always just used a large syringe for it. One for resin, and one for hardener. I ran into the same thing, I was unable to find pumps for the smaller containers.
Russell L. Babbitt Jr.
>You might look around at the drug store of grocery store for pump bottles containing hand soap or other products. There are a lot of products out there that have great reuseable containers.
Wayne in Topanga
>Try looking for these pumps at West Marine. They used to have pump kits that came with adapters and pickup tubes of assorted length to fit various container sizes.
Good Luck,
Wayne
Good Idea!
>Thanks
Re: West Marine
>Think I tried them, but worth another look.
Thanks
m
Leo Van Der Loo
>3M has a what they call the, EPX applicator, it uses the 2 barrel Duo-Pak in it, the epoxy gets pumped out and mixes with the exact amounts, the duo-packs are 1.25 oz.
Don.t know if this is kind of what you are looking for.
Have fun and take care
Leo Van Der Loo
Re: Resin Push Pumps? *LINK*
Juergen
>Check the product guide tab. Scroll down to the middle of the page.
West Systems
Rick Allen
>These pumps tend to be made for specific brands of epoxy. I know that West has pumps for quart sized resin. Evercoat epoxy also have pumps and the amount dispensed per pump is a lot less than West or MAS (which also sells pumps for their epoxy).
BTW West has 3 to 1 pumps and 5 to 1 pumps for different resin.
Gougeon Bros
Jorge Castaneda
>Hi Mark,
Try also Gougeon Bros, the people that make the West System, the pumps for epoxie are tricky, as they deliver a certain weight ratio bet resin and hardener. Keep in mind that the pumps for slow set are not the same as the regular ones, each formula has its pump.
$0.03
Jorge
Chuck Engstrom
>HI -- I have used the System Three resin with giant hypodermics (see pic) supplied by them for many years. Their mix is two-to-one by volume, and I've used as little as two cc's resin/one hardener with success many times. Though they are a little more cumbersome to use, they save a LOT of waste, and epoxy sure isn't cheap.
You could use these with other brands if you just figure up a weight/volume conversion table. The syringes have the B-D logo of Becton,Dickinson; you might be able to find them or similar at farm supply stores or such. I've seen them offered by other epoxy suppliers as well.
Best--
Chuck Engstrom
System Three Epoxy stuff
Thanks All
>Turns out I've got a West Systems Dealer not far away so I may try to adapt their pumps to my bottles if I don't go the soap dispenser route. I'm looking for dispensing ease rather than accuracy because I mix using graduated cups.
Mark
Syringes *LINK*
Wilford Bickel
>Large syringes like Chuck showed are common in the livestock industry. I checked one of our vet supply sources for the farm and they have them in packs or individual.
Sorry the link will not take you directly to the right page. Just enter syringe in the search on the Jeffers home page and then choose "Luer Slip Syringe" in the search results.
Jeffers (syringe source)
