obsidian
obsidian
obsidian
eliot d
>Do you think it would be possible to turn wood with obsidian? It's basically volcanic glass and is hard and very sharp, but I don't know how hard, nor if there would be any advantage. Still, we turners are always looking for an edge! (Ha!)
Re: obsidian
Re: obsidian
Hooligan
>I think that most likely the abrasive qualities of the woods would outweigh the edge. Not saying that it wouldn't be possible, but I certainly can't imagine it being practical either.
Re: obsidian
Re: obsidian
jwoodwright
>While stationed in Spain, I saw a Spanish Woodworker break a piece of Window Glass and carve the Grapes, Vines and Leaves on a Rocking Chair.
Obsidian was used for Weapons for Eons...
Probally Too Brittle to stand up to the beating a Lathe Chisle takes.
Re: obsidian
Re: obsidian
>I'm with jwoodright on this one. Obsidian might be far too brittle to sustain the pounding as the spindle (or bowl) comes around. You might be able to use it like a sandpaper (sort of like a garnet sandpaper). You may be able to use it as a scraper also.
Re: obsidian
Re: obsidian
>I agree. Both Flint and Obsidian can be chipped to create a very sharp edge but it's way to brittle for a powered lathe. Might possible work on my spring pole but I doubt you get the right profiles each time it does chip and you have to break out another good edge.
Re: obsidian
Re: obsidian
Russ Fairfield
>It seems to me that rocks replaced wooden clubs, and then the rocks were subsequently replaced by copper, bronze, and steel because they would hold a sharper cutting edge longer. Since obsidian is a rock, it is pretty close to the bottom of the evolutionary chain of cutting tools.
Re: obsidian
Re: Funny Thing
>I was just wondering if this thread shouldn't actually be moved over to the Neander Side.
Re: obsidian
Stop Me!!
Jim Shaver Oakville, Ont.
>Hi,
In my previous career as a geologist and having taught mineralogy to undergrads I had to smile when I saw this topic.
Obsidian in a highly siliceous rock , composed of mostly silica and impurities such as magnesium and iron and other trace elements. It�s a volcanic that flowed at surface, commonly under water. It�s hardness is about 5 on the Mohr�s scale, and it�s basically a volcanic glass. I have no idea how you could turn it, but if you were able to melt it you might have better luck with it blowing it as glass.
Just information that still rambles around in my head�now if you want to know about tectonics and the significance of some key indicator minerals of metamorphic transformations we could have some fun here�I know, You are just begging for that too!!
LOL
Take care,.
Jim
Re: obsidian
Re: Funny Thing
>That's why I answered. They think I'm pretty low on the evolutionary scale here at work.
Re: obsidian
Re: I think he was referring to using it as..
>a turning tool rather than turning it.
Re: obsidian
>Yes JL...
You are right..
Missed that in my reading of the topic... (opps)
It's softer than steel so...not a good choice then either.
take care,
Jim
back to work
Re: obsidian
eliot d
>Right, as a scraping tool, maybe -- not to try turning it.
Some people are having some fun with my crazy question -- I don't mind..
Re: obsidian
Ed Karch
>I have knapped knife and razor tools from it before and if you flaked it to a scraper profile I think it might work for a while. Good obsidian stock is not that easy to find.
Re: obsidian
Re: obsidian
Bill Turpin in WNC mountains
>Besides being very brittle it is VERY sensitive to sudden temperature changes. It will shatter if cooled too quickly. It is probably best left to the lapidaries.
Bill in WNC mountains
Re: obsidian
Re: obsidian
Winnemucca Lynn
>I have heard from some of my archeologist friends that some doctors are using it in place of scalpels sinch they can get a sharper edge on it.
