Bowl Stitching
Bowl Stitching
Bowl Stitching
RP
>I have a large walnut bowl I just finished. It developed some large cracks during the turning process. I'd like to put some decorative stitching across the cracks to make it look like I planed it that way. Can someone tell me how to do this and what kind of a pattern to use. I just will use bare copper wire.
Thanks
RP
Re: Bowl Stitching
Re: Bowl Stitching
Blake Washburn
>What I did on a bowl is I drilled equal amounts of holes on each side of the crack and strung the wire through like I was lacing a shoe. When you get to the end, If you want to hide the ending, cut and glue the two ends so that they are hidden in one of the holes. Or you can do a decorative tie at the end.
Blake Washburn
Re: Bowl Stitching
Re: Bowl Stitching
Norm Smith in Nova Scotia
>RP, I did the same thing as black did. Sometimes I use leather lace that I get from a sewing goods store.
Norm
Re: Bowl Stitching
Dick Hines
Re: Bowl Stitching
Dick Hines
>I had a walnut bowl out of burl crack. Other than the crack the piece was real nice. I took some thin sheet brass and cut some staples. Then I drilled holes on each side of the crack and glued the staples into the holes. One on the inside and one on the out side. Looked nice.
