no perch *LINK*
GaryG in MD
>Bill,
That's a really cute little bird house. These look like lots of fun to make and to look at. They would probably be a good seller too. They could be hung from little tabletop wire frames like Christmas ornaments.
I doubt that you intend them to actually be used, but some people might want to. In that case, as a birder, I would like to provide a bit of information. Bird houses that are intended for use should not have a perch. You can find many web sites which will confirm this if you Google [bird house "no perch"]. One example link is attached here. In it, as item number seven, you will find the following:
"7. There should be NO perch outside of the entrance hole. Birds do not need this perch to get inside. More importantly, the perch allows other predators a place to sit and harass the parents and baby birds inside, perhaps even killing them.
As a decoration, they look better with a perch because we have become used to seeing them that way. For use, skip it.
Again, what a fun item to make. Great idea. Thanks for sharing.
Gary
no perch
