We value your privacy.
>I use a homemade sanding ball with velcro on it and cut up some H&L sandpaper to fit it. I formed a shaft on it that I then flattened with a file so I can hold with long curved hemostats (picked them up at a model train show). Also, I only sand in as far as I can reach - especially if the opening is small. A Bob Rosand trick is to paint the inside black so you can't really tell that the bottom isn't sanded.
>Several methods. I use a piece of firm foam rubber (I think the block came with a pack of Micro-mesh) with sandpaper wrapped around it and gripped with 12" curved forceps. DON'T do this with your fingers through the holes in the forceps!!!! I also use a small firm foam ball covered with velcro and super glued to a dowel. If neither of those works I scrounge around the shop until I come up with something that does and if I can't, I put a collar on it with a small opening.
>I found 2 threads with pics of your Acme Sand-O-Matic. The link is to one of them and this is the other http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=86239
>Cyril, I just found it. Just look in the left column of your WC page. Under ARCHIVES, click on Turning Archives. Search for Sand-O-Matic... case sensitive. It's there.
Put enough sand inside the HF to fill it half way, tape the opening closed and turn the lathe on at a low speed. Let it run for several hours. The speed would need to be low enough not to hold the sand against the side of the piece so it can tumble. I have no idea if this works.
Really though, you would have to run at 50-100 RPM to do that. I don't think I could walk away from a spinning lathe, and I darn sure couldn't sit and WATCH a spinning lathe for two hours. ;)
>work better than sand. Terry Daniels has a setup that is an electric motor, turning a shaft that he can mount a chuck on, with pulleys stepping it down to about 30 rpm.
He mounts up a hollowform, throws in a handfull of rocks, switches the motor on, and walks away. Next morning, he pours out the rocks, blows dust for a while, and it's finished. Smooth as silk.
I'm working on a setup like this for myself. That'll solve a lot of problems with hollowforms. It really does work!
>for the shaft I use a 1"-8 Hex head bolt. I ordered bushings for my chucks so that I can use either chuck on the sander. Bill Turpin sent me some silicon carbide to add to the rocks and that speeds things up. Lan Brady sent me some rocks that they use and I am experimenting with those also. When I get finished with my new building I'll get back to experimenting to see what kind of rocks works best but for now I can say that most any rock will work, just some do it faster than others. I have the parts ready for a second one with 1 1/4"-8 threads so that I won't have to change bushings. This one will have 4 speeds thanks to my friend at the machine shop who had a gearbox off an old metal lathe that he had scrapped.
