PIC2
Andy DiPietro
PIC2
Andy DiPietro
Beautiful, Andy, and a photography question
Dinyar Chavda
>This is really pretty, Andy. I love the slight flare at the top.
I hope you don't mind if I ask a question of our photography gurus, i.e., what could have been done to make the form stand out more from the background? These old eyes could use more of a contrast.
Re: Beautiful, Andy, and a photography question
Andy DiPietro
>Hi fellow BWT member. You are always welcome to join in. I have been struggling to photograph my walnut pieces since they are dark and have a high gloss finish.
Thanks
Andy D.
Re: PIC2
>Nice Form Andi. As far as photo help I would suggest moving the lights further to the side. At least one of them anyway. It looks like their might be 2 other problems. Are you using the camera in Auto settings? Auto setting don't work that well with dark woods. They make the camera overexpose them. this not only lightens the piece but also overexposes the background. You might also be getting some flare into the lens. Try shading the lens to keep stray light out. This makes the image look soft and low in contrast.
The other thing is possibly Auto White Balance. The photo appears to be a little warm looking. I don't know what kind of lights you are using but you should set the white balance for these lights. Possibly the Tungsten white balance setting.
You have a nice piece there. Hopefully we can get it photographed better so everyone can really enjoy it. Feel free to e-mail me with questions about yourlighting setup
Re: PIC2
Andy DiPietro
>Hi John,
Thanks for offering help. My Nikon P4 is set to A mode with the following settings. .
White Balance: Incadescent
Metering: Spot
Image Adjustment: Auto
Image Sharpening: Auto
Saturation Control: Normal
Sensitivity ISO: 400
Image Quality: Fine
Area Mode: Auto
Auto Focus: Full Time
Fixed Aperature: Off
My tent lighting has
Upper left 500Watt Halogen Upper Right 150 Watt Halogen
Lower left and right are 65Watt Natural light Flood
What should I try next.
Thanks
Andy D.
Re: PIC2
>I just looked at the pic again. I'm a litle more awake this morning. This can be tricky to shoot. It appears that it's quite glossy. I say that because you can see all the sides of your photo booth. There is a dark square in the middle. That is of course the opening of the booth (and probably your camera also).
The first thing is exposure. When you meter using spot meter the camera only knows 18% gray.(That may not be true anymore because camera manufacturers have changed the metering programs quite a bit but it's probably close). Anyway what this means is the meter will give you an exposure that will make the piece gray. On Walnut you need to make the piece darker than gray so you need to underexpose what the meter tells you to do. If you have the camera on an auto setting you need to use the metering +/- override and go on the - side by as much as 1 full stop. The opposite would be true for white woods.
Now the light problem. Incandescent is correct on that setting. I think your overlighting it. To correct for the dark square you have to somehow change the booth. I mounted my top panel to my side panels with single screw in the center. This lets me close the gap in the front so the square is smaller. Then I put more white cloth between the camera and the booth to that the only dark square left is the camera itself. Sometimes this doesn't work if the piece is too glossy but that's another topic. Sometimes just putting the piece deeper into the booth will help.
Try using just one light and moving it around, usually on top and toward the front. This should give you one highlight and enough fill to bring out the color in the rest of the piece. Most people light the pieces too much so the piece looks flat. You need a darker side to the vessel to make it look 3 dimensional in the photo. Experiment with how dark. Usually it's darker than most people think. If one light just won't do it, then it's time to add some other ones. Normally if I'm using a 500 watt light the fill light will be about 250 watts and a little further away. If you have 65 watt lights you can just move them a little closer but they will show up as a spot. It's better to have a more powerful light further away because it will spread the light.
There are a lot more tricks but try this first. Let us know the results. I've been able to light pieces like this with one light and one fill reflector but the piece may not have been as glossy as yours.
Re: PIC2
Andy DiPietro
>Hi John,
The HF has five coats of Waterlox and I polished it with the Beall buffs. So it has a high gloss finish.
---------- denotes what I changed since the last picture
Metering: -------------- Center weighted
Image Quality: Fine
Area Mode: Auto
------------------- Exposure -1.0 stop
----------- I rearranged the tent so the HF is in deeper.
--------Upper left 150Watt Halogen Upper Right 150 Watt Halogen
What do you think?
Thanks
Andy D.
Re: PIC2
>Much better. Swithching to center wieghted metering means that the camera meters both the center and also some of thedges. The balance between white and dark helps the exposure reading. The using the -1 seemed to pull it even closer.
Now we'll work on the reflections. Try using a darker background to set the turning on. A gray or brown. This will reduce the funny reflection on the lower part of the piece. You may have to live with the upper reflection although you can change it's shape and possibly make it more pleasing. To do this take some black construction paper and simply tear it up. Then scatter small pieces near the edges of the uppper panel. If you look close you will see what's happening. It's like creating a half tone photo.
If you look at a newspaper photo realy close you will see it is only made up of black and white. The gray you see is simply 50% white and 50% black. If you use less black it gets to be a lighter gray. By scattering small black pieces on the top panel you can make the edges darker and less harsh. You might just try placing larger pieces around the edges just to change the shape of the light and hopefully make it look either more natural or at least less like a big square blob. I've also use squares and strips of wire screen which gives a similar affect. It takes about 2 to 3 thicknesses of wire screen to noticeably change how the light looks.
Re: PIC2, New PIC
Andy DiPietro
>Hi John I put 4 layers of charcoal screen and scrap construction paper. I think this may be as good as it gets??
Re: PIC2, Tent Setup
Andy DiPietro
