mini lathe
mini lathe
mini lathe
RYKER ACUNA
>While removing the chuck on my jet mini lathe I accidentally tightened the outboard hand wheel. This bound the lathe, and would not allow the shaft to spin. Before I knew what I did, I sprayed wd40 on either side of the headstock. I thought the bearings might have heated up and locked. Well they were not. When I loosend the hand wheel everything was fine, except. When I run the lathe it sounds as if there is not grease in the inboard bearing? I thought they were sealed bearings? Now what do I do? It still runs fine but it really screams at high speed. I dont want ruin anything. What to do now? replace the bearings? repack the bearings? Or let it run out the wd40 and it will quiet down? thnx
Re: mini lathe
Re: mini lathe
Pete LaBelle
>By overtightening the hand wheel, I assume it pressed up against the the casting of the head stock. It may have pulled the ball bearings together some and need to be relaxed. If the hand wheel is not rubbing the head stock, with a brass mallet, squarely strike both ends of the spinde, maybe with a pad of a solid hardwood between the steel and hammer. This may cause the bearings to move some and get rid of the binding. Check too for any iron "sawdust" caused by rubbing metal parts.
Good luck.......
Re: mini lathe
Re: mini lathe
ryker acuna
>Thanks Pete,
I will give that a try tommorrow. I did check for tell tell signs of metal dust but did not see any. I disengaged the belt and manually rotated the shaft. I could the feel what seems to be the inner bearing turning when I rotate the shaft. I think the handwheel has slowly been tightening for awhile and I never noticed it until now. I think that bearing might be a little worn. Thnx for the tip I will give it a try.
Re: mini lathe
Re: mini lathe
>One the jet the handwheel tensions everything. You should tighten it just enough to stop any wobble of the spindle but no more. To tight causes binding and possibly noise. Too loose and you get some wobble in the spindle. If both bearings seem to be seated properly and you still have noise with the shaft loose enough to wobble you may have a bad bearing.
