REAL MILK PAINT
Got the Box Elder Blues
Andy DiPietro
Andy DiPietro
>Last week I picked up two 22" diameter x 4 foot long pieces of Box Elder. Unfortunately the pieces have heavy blue stains in them. I turned a small hollow form and bleached it with wood bleach and Clorox. At best the colors look okay but the blue stains remained. Is there a good way to remove the blue stains or do I really have a couple pieces of low BTU Firewood. I saw a posting once about a two-part bleach, but I could not find a supplier. Suggestions please.
Re: Got the Box Elder Blues
Chuck Engstrom
>There's a two-part wood bleach made by Kleen-Strip, often available in Ace/TrueValue/Lowes/HomeDepot stores. You can go beyond included instructions to apply mixture multple times, and even to apply part B by itself after you've applied the mix several times.
Do be careful in handling, especially Part B alone. If you get it on your hand, you'll get a bleached spot, and you will feel some tingling all the way up your arm for a while. Wear some kind of barrier gloves.
I have used this on boxelder and it will mostly leave the red alone, but I haven't had any experience with the blue stain you're trying to deal with.
Best--
Chuck Engstrom
Ed Karch
>The big boys to;d me to use limon juice on blue stain. I thought that they were BS-ing me. I tried it on maple to no effect. Tried it on cherry and it took the blue right out. Your milage may vary.
Andy DiPietro
Still have the Box Elder Blues, Need Suggestions
Andy DiPietro
>Here is what I have tried without any success:
1. Wood Bleach (Oxalic Acid)
2. Clorox Bleach
3. Lemon Juice (Real Lemon)
4. Oxyclean
5. Hydrogen Peroxide 3%
6. Orange Cleaner Formula 2050
7. White Vinegar
I have not tried the two-part wood bleach made by Kleen-Strip. I will try that this weekend but I am not sure bleach is the answer.
Blue Stain is a fungus. Maybe I need to use a Fungicide. Does anyone have experience using Fungicides on wood?
Re: Still have the Box Elder Blues, Need Suggestio
John Veerkamp
>IMHO the blue stain with the red and other colors can make BE look like expensive marble. I leave the blue alone and like the results.
John
Andy DiPietro
Andy DiPietro
>You make a good point. Maybe the blue stain is really a feature. Let me know what you think of the following two unfinished pieces. My photography needs allot of work.
Andy DiPietro
2nd piece
Andy DiPietro
>The first piece I used wood bleach. This second piece I used just Waterlox. The bottom will get turned off when it dries.
