Calling Bill Grumbine
Don in Central Illinis
>I just got a dentists light (gloat) and was wondering where you fastened the light in relation to your lathee. Is it on the ceiling at the tail stock, in front of the lathe (opposite side you normally stand) or directly over the lathe? When I find time to install, I'd like to do it only once. TIA.
Re: Calling Bill Grumbine
Re: Calling Bill Grumbine *LINK*
Anthony Y
>It's on the ceiling, at the 5 Barns picnic we kept bumping our heads on it. Here's a link to some pics, it's in there somewhere
link to 5 Barns pics thanks Ron
>Thanks. It looks like it is mounted on the ceiling on the opposite side of the lathe that you normally stand on. Now if I can just find the time to mount this.
Bill Grumbine (Kutztown PA)
>Hi Don
The light is mounted to the right of the tailstock end of the lathe, and probably close to two feet off the center line. I see Anthony has given you a link to some pictures. If you need more info let me know. I had to move mine once, and I might move it again. It is not fun moving it, especially since the lag bolts holding it up are screwed into 63 year old red oak beams, but it sure is worth it to get it just where it works best.
Good luck with it!
Bill
>Thanks, at least if I have to move it, it will only be lagged into 3 year 2X4's.
