Thanks Everyone!
Thanks Everyone!
Thanks Everyone!
Gary B in Central NY
>I took your advice about the skew, what a difference. Besides smoothing out my tool rest, I moved it closer, and lower. But the big difference was entering the work with the cutting edge 45 degrees to it. now I can cut a smooth shape. I was entering the work with the cutting edge parallel to the workpiece. Also, am I supposed to angle a gouge in the same manner? Thanks for the advice, I'll order the book soon.
Gary
Re: Thanks Everyone!
>Gary I usually have the gouge at about the same angle. It's also nice to rotate the gouge so the flute is pointed in the direction you are going. Not necessarily pointed at 9 oclock or 3 oclock but more like 10 and 2. How far you rotate the tool is more a matter of feel but most people do rotate it so the flute leads in the direction you are moving.
